Question about Foxconn (865G7MC-ES) Motherboard
Hi. i have a probelm. my pc sarting but i hearing 4 short beeps continuosly. what i can do to solve?? thanks.
  • office20 Jul 31, 2010
    i did all , what u tell, i'm trying to boot from cd, but the pc has restarting every time, i try to boot in safe mode and command prompt , but i recived the blue screen with the windows message : if you see first time this....." and "stop :0x0000007B.
    I thin is about the hdd or some virus or windows has crashed.
    what do u thing???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
It can either be a problem with *********** borad or your Memmory.
Remove your Rams from *********** board slot and clean their legs with an eraser. Put them back again into slots and see if it removes the beep and get the machine ready for running.
If that doesn't help and if you have 2 Ram modules then try each one at a time and see if it works. If so the working one is good and the other one is damaged.
You can also try and get an alternative ram module from one of your friends and see if it is working on your machine. If you find there is no problem with the ram modules then it must be a problem with *********** board (Try the ram modules in some other machines to ensure their condition). Most of the motherboards come with a 3 or 5 year warranty; so hopefully you are still covered in that case.
Please let me know if you need any clarification regarding my answer.
Best Regards NextDoorNerd
Posted on Jul 31, 2010
  • Deepak Dharan Padmini
    Deepak Dharan Padmini Jul 31, 2010
    The blue screen errors are usually associated with hardware errors and occationaly software errors. Since you have the problems during the booting of the machine, we can assume that it is because of some hardware trouble. However as a first attempt try and take apart your machine and re-fix it. In many cases this will help you solve the problem.
    There can be a few reasons for your problem.
    The first one is it can be a problem with your ram slots or with the chips in your ram (damaged memmory areas). Try using a single ram module (good working one) in all different slots and see if it helps.
    The second problem is a usual scenario, it is some problem with the bios firmware which causes the reboot of your machine. In this case you need assistance with your motherboard and bios; you need to consult the store you have purchased it from (any local computer shop will be able to help you with this problem).
    One of the other major other is the problem with your hard disks. It might be because of the boot volume is corrupted and your operating system can't access that partition for a successful boot up. If you think this can be your problem then try checking your hard disk with a check disk application using some live cds; most of the linux disks come with the applications like gparted or you can use chdisk (http://www.cgsecurity.org/wiki/TestDisk_...) which can also be used for this purpose.
    Hope This helps
    BestRegards
    NextDoorNerd
Why does my Frigidaire (Gallery Series) stove always beep all by itself ? It starts whenever it feels like it and hardly stops !
Hi Roger Uson, thanks for the inquiry!
It sounds like it could be an issue within your control panel or sensor of your Frigidaire range and that is why it beeps. I would recommend having a professional come out to properly diagnose your appliance. I hope this is helpful. -Matt
Sep 23, 2014 | Kitchen Ranges
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
I have an intel dot station 2300, it doesn't start ,it sounds with short beep continuosly like below "... ... ... ..."
A continual beep is usually a sign of the cable being backwards or upside down whatever the case may be
Jan 18, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
Beeps on start up
Hi there.
The continuous beeping means that there is a problem with the memory, take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> e1bc638.jpeg.
Good luck and thanks for using FixYa!!
May 21, 2009 | Compaq Evo Notebook N150 Notebook
Factory reset my dell latitude 100l
i've done mine before this way but yours might be different
Try it anyway
Turn it on and straight away keep tapping the F10 BUTTON CONTINUOSLY until you hear a beep,leave it and let it go to work
Mar 10, 2009 | Dell Latitude 100L Notebook
Computer beeps on sart up no display
Try another display or display cable.
Jul 07, 2008 | Computers & Internet
P4 compaq 2.4GHz doesn't boot up
Sounds like a keyboard error. Make sure there are no stuck keys and all cables are secure. Turn of pc before checking.
Jun 21, 2008 | Computers & Internet
Tower Beeping
As I can see the problem is not monitor but your PC if computer chasis beeping, depends on number of beeps the problem can be VGA card one long beep and 3 short or RAM if it beeping one by one short beep and finaly CPU if it continuosly beeps like police sirene. If beeps are pointing to VGA or RAM you must open computer chasis and plug out VGA and RAM and clean dust out of slots and of VGA card and RAM as well with painbrush and vacum cleaner and plug them back.
Dec 12, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Foxconn (865G7MC-ES) Motherboard Logo
56 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
