Question about Hotpoint Washing Machines
Hi my hotpoint wma63 fills with water for a wash, then empties
Hi my hotpoint wma63 fills with water for a wash, does a couple of drum rotations then empties, filter is clean, motor brushes good. What could the problem be?
Motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Posted on Oct 15, 2010
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
The drum on WF325 hotpoint washing machine does not rotate
Sounds like your gearbox/transmission has went out. Usually cheaper to get a new washer than to replace. Sorry.
It is not the motor, if the water is draining - pump is attached to motor.
Hope this helps...
Jan 07, 2012 | Washing Machines
Hotpoint WF860 drum not turning. Belt checked all ok, no error codes it just fills with water and goes through the cycle filling and emptying when it should and the drum stays still. Can someone help?
ours did the same as this........ it needed a new control board after checking everything you have mentioned. it was a couple of years ago and at that time it was a hotpoint part only. but they can be picked up on ebay for around 30-40 quid.
Oct 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
I have a Hotpoint ultima stream washing machine (WMA63) which the light says the cycle has ended but the water will not empty and we cannot open the door, any suggestions??
first to empty the machine--lower the drain hose at the back below the tub into a basin--once all the water is out--wait for about 3 mins and the door will unlock--then check your filter--probably pump prob
Oct 27, 2009 | Washing Machines
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Checking for items in 'sump' of Hotpoint WMA63
hi you need to pull the washer out. tip it up and at the bottom ov the drum there is a black pipe from your drum to the pump its big on the drum and sall end is your pump end take it off at the drum end and look in there if not try takeing your pump off not that hard to due hope you find it stuart
Jun 24, 2009 | Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
217 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
