Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
Samsung hd103sj slow write speed and stutter
Samsung hd103sj 1TB drive has slow write speed but reads to it very quickly and it stutters music playback. The 320gb drive is fine and also sata, but not Sata2
New drive added to Via VT6421a adapter alongside Hitachi 329gb HD
formatted OK, just over two hours on windows XP sp2.
Copied 220gb data over three evenings... somewhere between 4-6 hours I guess... seems OK on that.
Transfer of copied info to the Hitachi or eithe IDE drive, or an attached usb Seagate 250gb drive is nightmare slow.
System comprises: 400watt power supply. old asrock MB with Athlon2600. runs at 2gb seems faster normally than my new work laptop Separate video card, wireless, card for firewire (currently unused).
Not too sure about Hutil as it seems inaccessible on Samsung site, and not sure if I need jumpers on the drive.
SOURCE: Drive terminators
Translate from portuguese to english... Meu HD também estava com este problema, o que fiz foi limpar o contato que liga a placa lógica do HD ao leitor do disco rígido que estava oxidado. O problema ficou resolvido.
Posted on Dec 30, 2007
SOURCE: sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Posted on Mar 17, 2009
brukau747
  • 51 Answers
SOURCE: my 250GB HD250HJ SATA has stopped booting with my
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Posted on Aug 31, 2009
  • 425 Answers
SOURCE: I've connected my Samsung 250GB HD250HJ SATA drive
On the front of the drive there will be an example of how to set the drive to slave. Jumper pins are small black squares put them in config that is on drive then boot up.
B52Computers
Posted on Dec 05, 2009
bronk50
  • 27725 Answers
SOURCE: My Samsung HDD 160GB started clicking few weeks
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
then press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will scan and repair any bad sectors automatically fix any corrupt files on your hard drive
hope this helps good luck
Posted on Oct 18, 2010
While accelerating the car stutters and has a slow acceleration
Does the vehicle drive fine at slow speeds then it has problems?
Dec 07, 2013 | Ford Cars & Trucks
What could cause the car to stutter when under load going up hill.
It sounds to me like a passing gear issue. Or even and Over Drive issue. Try this to find out. When you put the car in gear, instead of O/D, try regular drive. If you have a push button O/D then deactivate it. If you only have Drive, then try shifting into 3. Run the car up to the same speeds you were having problems with. If you don't have the issues with the higher RPM's then it is an Overdrive/Highway gear issue. If it still stutters, then it could be a fuel delivery issue. Good luck.
Mar 28, 2013 | 2001 Dodge Stratus
Just put in a new hard drive in the SATA port 3 and my computer sees the device but i cannot find it on my computer, the hard drive is a samsung HD103SJ ATA Device 1TB
You need to go in the bios and turn it on so the motherboard tells your HDD controller that it is there. Another thing you may need to research is if your motherboards BIOS is able to read a 1TB Drive most need an update. IF you have no clue what I am talking about I can walk you thru it but then I will need to know what motherboard you have, also if it is a off the shelf pc or a custom rig
Jul 31, 2010 | Acer Aspire Predator G7710 PC Desktop
I have a 1986 Bronco II with 4 wheel drive and automatic trans. 185,000 miles when it warms up it will stutter and lose power when you try to accelerate. I am able to baby it up slowly to a faster speed...
Try checking the spark plugs gap and ignition wires and cap and rotor sounds like a spark delivery problem to big of an air gap at cap/rotor or plugs what size engine? Carburetor or fuel injected? It makes a big difference
Dec 29, 2017 | 1986 Ford Bronco II
2002 toyota corolla - engine stutter?
its the drive belt tensioner dampner it goes bad and sounds like a bad engine vibration when accel and on cold start up
Feb 24, 2010 | 2002 Toyota Camry
2004 1.9Tdi Audi A6 engine stutter/intermittent cut-out
It sounds like who ever rebuilt it forgot to line up the gears in the gear box. You might see if they can redo it for ya, tell'em to take there time and slow down, an you should be alright.
Jan 25, 2010 | 2004 Audi A6
Mazda MPV 2004 - Stutters, check engine light came on
chances are fairly good it's the coils - I've posted about this on Edmunds. the OEM design is truely idiotic & has a vent that allows moisture down into the plug well - that shorts the spark & causes misfires. On our 2004 MPV I got away w/cleaning & drying them extremely carefully then sealing the vent w/silicone as a temp measure, then ordered perfect replacement after-market coils off ebay that sealed the wells & stopped the problem -and- were a tiny fraction of the OEM price.  good luck, BK
Nov 17, 2008 | 2004 Mazda MPV
Strange engine stuttering problem around 1500 to 1800 rpms.
YOU CAN TEST IT WITH A OHM"s meter or a multi meter one is your ground wire the other two send the signal to your computer.what you are looking for is when you rotate the throttle do it as slow as possible and as steady.If the reading jumps alot when you slowly rotate the throttle then it is a bad tps.let me know what the outcome is.Thank you for using fixya
Aug 23, 2008 | 1998 Honda Accord
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
1,021 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
