Question about Sport & Outdoor - Others
1988 evinrude 4hp deluxe no spark when pulling starter rope
  • 65 Answers
SOURCE: evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
Posted on May 08, 2009
scott586
  • 41 Answers
SOURCE: Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
Posted on May 19, 2009
dontbother10
  • 2220 Answers
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Posted on Sep 17, 2009
Testimonial: "cheers"
  • 1388 Answers
SOURCE: I have an 8 hp
I have several older Briggs engines on mower and tillers and was having similar problems. I purchased electronic ignition kit (Nova II) from lawn mower shop and installed with easy wiring instructions (about $12). Used same old coil. Engines ran better, more power and never needs adjustment. Look here for instructions:
http://gardentractorpullingtips.com/images/novainst.gif
One thing to check however, you may have pinched kill wire when removing/installing starter cover. Temporarily remove wire from kill tab on coil and check for spark. Good Luck.
Posted on Aug 28, 2010
MNfisherman
  • 11896 Answers
SOURCE: 4hp briggs and stratton roto
There are 3 metal arms that come out when the recoil is pulled. These arms can get dirty or rust and stick in so the recoil won't engage the flywheel or crank. .You will need to pull off the recoil and lubricate and work back and forth the arms.
Posted on May 16, 2011
How do you fix rewind on Johnson seahorse 4hp
Usually, replace the recoil spring.
You also, may be able to increase the wrap tension by:
1) pull spark plug (easier to manipulate spinning the motor)
2) wrap the extra loop of rope around the start pulley gear.
sometimes there is a bracket, etc. to work around
Jun 12, 2018 | Johnson Boating
How do u remove recoil spring assembly that is held in place by a roll pin on a 4hp Briggs and stratten
I suspect you asked this question because your recoil starter rope has broken , so first let me say be extreemly carefull the coiled spring on top of rope pully has a lot of tension to it , it can and will hurt you if it gets out of the pocket it sets in, what ive allways done is to NOT remove the pully at all but hold it with a large C clamp i put this on right after i get about 6 good turns to tighen the spring then i apply clamp , use a razor knife to cut ball off end of old rope and pull out using pliers thread new rope from outside rope guide to into the rope pully and knot if off in original hole (use a lighter to part melt rope end) measure off about 5 feet of rope and tie starter handle on there then its simple just slowly let clamp pressure off the pulley will pull rope in to cover automaticly done !!!
Aug 24, 2014 | Mtd 22" Yard Machine Push Mower
Evinrude troubleshooting
check lower unit oil if ok . pull prop off see if it has a wod of string around the input shaft behind prop sounds to me its in a bind
Nov 19, 2013 | Boating
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Starter rope will not pull. Will pull smoothly
Lou
Sep 17, 2009 | Bosch Garden
It is a 1982 4hp outboard evinrude what is the start sequence
Open the fuel valve ( at the back near the spark plugs).
Pull the choke knob ( SB side at the lower front of the motor)
Set the throttle handle in 'start' position ( abour 1/4 of the travelling way from SB to Port)
Pull the rope starter.
Should start easily.
Nov 05, 2017 | Boating
Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Evinrude outboard motor starter rope
May 06, 2009 | Boating
Sport & Outdoor - Others Logo
76 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
