Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have troy built lawn tractor with a briggs and stratton 18 hp ohv intek engine. It has 50 hours on it. Its about six years old. It is hard to start. if it does start it flutters, fills the air with white smoke and spits oil out of the exhaust before shutting off. Could it possibly have a ring thats not seated or broke. What do you suggest. Egine Model#3JD777 Type#0233E1 Code#030904ZA
  • 10,865 Answers
Hello. With only 50 hours on it, it is unlikely that you have a ring problem. That said, let's do the following.
1. Install new spark plug[s]
2. New Air filter
3. Drain the gas tank, replace the fuel line and then fill with fresh, new fuel. Do not use a can of fuel that has been sitting around for more than one month.
Charge the battery fully and turn it over. It should take off. If not, remove the battery and take it to any auto parts store to be tested.
Finally, if you are still having a flutter at start, get a bottle of a fuel additive called seafoam. This will thoroughly clean the engine and the carburator. Run with this fuel while mowing for an hour.
These steps will generally solve the problem. J.
Posted on Jul 31, 2010
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Battery want charge... ok i paid to talk w/ a
Sounds like the voltage regulator is bad--will run the battery down!
Feb 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
190 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
