Question about Karcher 1750 Psi Elec Pressure Washer
Motor running, water supply adequate but when
Karcher 6.85 motor running, water supply adequate but when trigger pulled, pump not activated
  • 700 Answers
Clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Posted on Jul 31, 2010
Testimonial: "It worked, thanks."
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
I own a Karcher 3000 pressure washer. There is no water pressure. I've checked the obvious...hose to house, kinks, attachment is tight....Enging runs, no water pressure.
I had the same problem. On the top of the pump there is a little nickle colored button cap. It is attached on both sides with a screw. What this actually does I don't know but when I took it off with the motor running and put my finger over it the pressure come up. I also discovered that having the motor running and taking the nozzle tip off and pulling the trigger would clear the pump to work until you let of the trigger again. Weird but it works for me.
Aug 06, 2010 | Karcher Garden
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
Karcher k3.86 motor runs but has no pressure when trigger pulled, motor doesn't go faster.
Could be a pump, but most likely the unloader valve is stuck open. After replacing/repairing the valve, do the following to prevent it in the future: after finishing using it, unhook both hoses and pull the start cord on the engine several times to empty the water from the pump and valves. This is especially necessary when using hard water.
Nov 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher 1750 Psi Elec Pressure Washer Logo
653 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
