Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Power went off in our whole subdivision. We didn't plug off the refrigetator from the outlet. When the power resumed, the refrigerator no longer cools. The freezer section does not turn water inside to ice.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Is the refrigerator light off too ?if off, it means there was problem with the electrical controls. the possibility is your refrigerator use the relay and automatic stabilizer system.The main key is the refrigerator will be cold if the compressor is running, the compressor will run if there is a current and voltage flowing there
Posted on Jul 31, 2010
My wife pushed the ice dispencer then power went out tried plugging into other outlets yet nothing
Do the other outlets you plugged it into have power and something else plugged into them work such as a toaster /blender ect?? if all outlets in kitchen out their probably is a GFCI type outlet that has the reset button on it. Sometimes their in the kitchen or depending how the house was wired when built they could be in a bathroom or even garage. One outlet has that reset button but could have up to 6 outlets wired to it
Aug 16, 2011 | LG LSC26905TT Side by Side Refrigerator
After many power outages in our area, my GE Profile refrigerator is running warm. The freezer is cooler than the refrigerator, but it no longer freezes.
very first thing remove th eplug from the wall and check in coming power should be around 120 volts, They always say if having power problems unplug frig ! if the power isent correct leave it unpluged and check a diffent outlet in your house you may have to get an extention code to use a diffent outlet till this outlet is repaired , let me no what you find
Jul 27, 2011 | Refrigerators
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
Hi there, i have a two door westinghouse fridge it's 4 yrs old, we had a storm monday afternoon and came tuesday morning it had a power search then the whole thing just swtch off and also all the major...
Unplug the fridge, plug in a different appliance to the outlet to make sure the outlet isn't bad.If it trips the breaker for that circut might be bad.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Westinghouse Refrigerators
Fridge went to gas when power went out. when power came back on fridge didn't swith back to power. worked until gas went out. is there a problem with a switch somewhere or does the unit need replacing
Many RVs / Coaches have the fridge power receptacle protected by a GFCI outlet that is located in the kitchen, perhaps bathroom, areas. Check to see if this outlet is tripped. If it isn't, try plugging a lamp into the fridge outlet to see if it works.
If it does, then the control board may have gotten spiked by a converter surge while power was being lost (also a sign of a failing converter). You can also measure the resistance of the heating element with a multimeter. You should see about 44 ohms (give or take 10%). If the heating element is out of tolerance, the fridge won't use it, but it should throw a code indicating a problem.
If the outlet doesn't work, look for other dead outlets in your coach. Double check GFCI outlets, make sure they are not tripped. And, of course, make sure that all your breakers are turned on, and not partially tripped as well.
Jul 14, 2010 | Dometic RM2852 Refrigerator
Refrigerator has lost power no eletric to inside light, not cooling not freezing
First , check if is power in the outlet where the fridge is plugged in by plugging something you know works (table light , radio,etc.) , if it doesn't work , means there's not power at the outlet what could be a trpped breaker , burnt fuse , burnt or loose wire at the outlet, or a bad outlet ; but if you got power in the outlet , probably the fridge cord or its plug are bad.
Oct 15, 2009 | Whirlpool Refrigerators
Our power went out for a few minutes yesterdat and since then our refrigerator and freezer aren't working. What could cause this problem? -Thanks.
first of all I would check the outlet where your fridge is plugged in to make sure the power surge didn't affect it. maybe plug in a lamp. if it is ok, and the fridge will not start at all, i would check the relay/overload on the compressor as it may have been compromised by the power surge when the power came back on. these components start the compressor which in turn starts the cooling/freezing of your fridge. hope this helps.
Oct 13, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Sep 07, 2009 | Haier HNSB02 Refrigerator With Ice Box
Fridge, lights went out and is no longer working
be sure there is power to the outlet and check the cord where it enters the back of refrige and see if any wire burnt or frayed. unusual for everything to go out.
Jun 12, 2008 | Magic Chef Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
137 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
