Question about Stanley Bostitch HP118K 23 Gauge Headless Pin Nailer Kit
How do I change the counter to zero on bostich 607
How do I reset the counter to zero on the bostich 607? I was given this counter as a gift... help I am stuck 159 and climbing as I try to figure it out!
The numbers on the Bostitch Model 607 are able to be rotated when it is compressed into its stamp position. Either use a toothpick, wooden pointer, or fingers to rotate the numbers to 999999. It is important not to use anything hard to rotate the number wheels as this could lead to damage of the numbers themselves. I have found it easier to start with the largest number,rotate it to its respective 9, and then move to the next lower number. Once at 999999, when it retracts it will force rotate all the numbers to 000000.
Posted on Nov 19, 2010
Reset counter
You cannot reset the counter to zero on your own. :) Call your authorize service center to replace your counter PCB.
May 03, 2013 | Canon iR 2022 Printer
It says "unable to clean"
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
Completed instruction to set Purge counter to zero. Done. Hasnt solved the problem. Machine stil reports "Unable to Clean" & "Machine Error 48" How do I empty the "Ink...
Dec 20, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean code error 46
All you need to do is to reset the purge counter
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Feb 03, 2010 | Brother Office Equipment & Supplies
Waste Ink Absorber is almost full
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Remove the vcr display from the TV screen in a Toshiba w-607 vcr
push the display button on your controller until the counter is gone
Sep 10, 2009 | Toshiba W607 VHS VCR
How to change counter reading in ir8500
You can not. The chip needs to be reflashed by Canon in order to be reset to zero
Jun 18, 2009 | Canon Office Equipment & Supplies
Stanley Bostitch HP118K 23 Gauge Headless Pin Nailer Kit Logo
636 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
