Question about Nintendo DS Lite
Orange power light comes on when you charge the ds but it will not switch on
    President:
  • 1,139 Answers
This is due to the L2 inductor chip either being faulty or fallen off of the board. It is very common for these chips to come off the board if the ds is dropped. Below is an image showing the L2 inductor chip. There are lots of guides of how to take apart your DS. You could look one of these up and check the inductor chip is still present.
Hope this helps
Posted on Aug 01, 2010
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
Jul 06, 2013 | Nintendo DS Lite Console
Tip
DS Lite fuse replacement F1 F2
Does your DS lite refuse to charge?
Does the orange charge light not come on at all?
Has your DS stopped switching on with no green light at all?
Well this is the guide for you.
Remove the DS lites base plate (for a guide on how to do this see my other tips and tricks) and locate F1 and F2 (see pics)
F1- Charging fuse. Change this one if you have the following issue:
Orange light doesn't come on at all when the charger is inserted and a battery connected.
F2- Console power fuse. Change this one if you have the following issue:
The DS lite console charges but refuses to power on.
If you find that the DS lite console neither charges or switches on i.e. no lights come on, not even for a brief time you can replace both fuses and it "should" resolve the issues, however, I cannot guarantee this as there could be other factors for the lack of power e.g. water damage.
To change a fuse you need to first remove the old one, do this by desoldering either side of itand remove it from the board.
Putting the new fuse on is a little trickier, you will need to hold the fuse in place with a small enough item that will not get in the way ofthe soldering process such as a cocktail stick or tweezers. Solder either side of the fuse to the board taking care not to make a bridge* with the solder. Give your newly laid fuse a test to be sure you have done it correctly, put the DS lite back together and then your done.
*Bridge - A solid connection made over or around the fuse thus bypassing it.
I hope this helps and I have to say that I take no responsability for any damage that may occur whilst following my tips/ guides.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Jun 27, 2009 | Nintendo DS Lite Console
My DS power
How long have you had that battery in your DS? The more you use (play and charge) the battery, the battery's capacity is decreased. Try getting a new battery at,
usg.html">http://www.calcellular.com/ntd-ba-usg.html (for DS lite)
or
nds.html">http://www.calcellular.com/ntd-ba-nds.html (for DS).
Your welcome
Dec 29, 2008 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Is it a costly repair job or buy a new one?
could be you need a new battery...wotrh a try. Always go for the cheapest option first.
Jan 07, 2008 | Nintendo DS Lite Console
Beyond Repair?
I would try and get a new DS if I was u
Jan 04, 2008 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo DS Lite Logo
354 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
