My Whirlpool duet sport washer is spilling out the water from the detergent dispenser all over the floor. Can you give me your opinion? Thanks!
  • 171 Answers
Sounds like the hose from the detergent dispenser to the tub is clogged.  this is rubber so i would not want to try to force anything through but you might want to try something along the lines of a plastic cable wire tie but be very gentle.  other than that i would call for service.
Posted on Jul 31, 2010
Whirlpool duet sport is clogged. Water is bypassing the detergent dispenser, and leaking out of the washer. No water is entering the washer. HOw can it be unclogged?
If you take the drawer out you may be able to gain access to where the clog is, if not remove the lid of the machine and you will see the fill hose from the drawer to the tub. You may be able to remove the pipe without removing the dispenser housing or you may be able to get to the blockage by removing the pipe from the drum.
Dec 28, 2012 | Whirlpool Washing Machines
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Whirlpool washer overflows at detergent dispenser
Hello, I worked on a problem like this a few days ago. Your problem is going to be a blockage in the inlet to the drum. To fix this problem find the inlet pipe normally located above the door behid a flap of rubber..push your fingers up there to see if you can feel a blockage..If not your going to have to remove the lid of the machine to access the pipe that leads from the detergent drawer to the tub. Look at the rear top of the machine..You will see three screws....remove them and push back and lift the top panel (lid) now you should be able to access the pipe. Pull the pipe off and clean it out, i suspect you will find a sock blocking the pipe :) If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet sport is leaking out of large amounts of water out of the detergent compartment. it seems as if the water will not travel into the machine. any ideas?
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Sep 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent dispenser won't empty
TAKE THE TOP OFF AND ON THE DEPENSER ASSEMBLY IS A PLASTIC CAM MANY TIMES THESE POP OFF IF SO JUST POP IT BACK ON IF IT ISNT BROKEN IN PEICES
Jan 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
