Question about Canon imageRUNNER 3035 Black and White Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
I have a canon Imagerunner 3035. The copier says that it is out of staples, i filled the cartridge with staples, the cardtridge is not missing anything, but the copier will not automatically sense the staple refill. How can I get the copier to sense the staple refill?
  • Anonymous Mar 18, 2014
    Stapler is empty how do i refill it
  • Anonymous Mar 25, 2014
    i have f2-64code in my copier, i have refilled the cartridge but yet still show code f2-64
  • 1,219 Answers
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Posted on Jul 31, 2010
Error code E000019-0000
you must empty the bottle with waste toner
Dec 04, 2013 | Canon imageRUNNER 3035 Black and White...
Savin C3030 copier. refilled staples, but copier thinks empty. How can I get the copier to sense the staple refill?
There is a sensor that tells the machine if there are staples present. Check to see if it has been moved out of position or if the wire going in has been broke or crimped
Mar 29, 2012 | Savin 8035e Copier
Copier says out of staples but has staples
take the cartridge out and see if there is any staples jammed up in the slot where the cartridge assembly sits.
Dec 19, 2011 | Canon imageRUNNER 3035 Black and White...
I have the canon imagerunner 3035- how do i find the serial and model number?
simply print out a report . or press the counter button and u can see it on the bottom of the screen
Sep 07, 2011 | Canon imageRUNNER 3035 Black and White...
How do i refill the stapler cartridge? i can't figure out how it opens !
u can see a handle at the front end of the copier below the finisher tray .just lift it and pull forward. the stapler is on the back side of the finisher .
Jul 28, 2011 | Canon imageRUNNER 3035 Black and White...
Canon ir 3035 xerox machine i am facing one problem i.e. error code of E000020, plz kindly help me what is the problem.
that is about toner,
- may be toner was empty (the first you must try) after you fill the toner, you must turn off and on again.
- toner sensor was loose or broken (second trial )
- toner motor was not work.(the last)
good luck
May 17, 2011 | Canon imageRUNNER C3200 Copier
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon imageRUNNER 3030
Stapler is located in the finisher. Open finisher door, remove empty staple cartridge, insert new staple cartridge, close finisher door. Check canon.usa.com for operators manual.
Sep 14, 2007 | Office Equipment & Supplies
Canon imageRUNNER 3035 Black and White Copier Logo
845 people viewed this question
old marine
old marine
