Question about Car Audio & Video
I just bought the car last week, and only the right front speaker is working. I thought the stereo was bad and replaced it with a new one only to find the same issue. Is it possible that they may have a speaker board or module for the speakers elsewhere in the dash that could be bad? I did turn the car on once and both rear speakers worked, and the right front, but the left front has never worked. I hope this is an easy fix!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
How the repairs are:
first check by crossing between your car's audio output cable, the right front with the front left speaker.
  • if the same: Front Right speaker sound and Front Left speaker still does not sound. it means, speaker ( Front Left) is damage.
  • if the opposite: that the sound is front left speaker. It means there is a problem in your car audio, in 4 ways audio ouput system : FL (Front Left), FR (Front Right), RL (Rear Left), RR (Rear Right). One of the four audio output of FL was not working anymore. You have to replace the audio amplifier IC. sign of the IC, has a lot of foot pin. and attached to the body / case your car audio.
Posted on Jul 31, 2010
Every stereo has it's intricacies, once you learn the controls then you can adjust the sound. if you have adjusted the balance to equal, then you may have a broken by door swing ground or positive, sometimes the ohms are split by a common positive connection (front and rear) contained with in the circuit of left or right. This crappy circuit could kill 3 of your 4 speakers, but then with the addition of an after market sub, who knows what kind of monkey business has been committed. Start from scratch in stead of chasing down electrical gremlins. Run new wires to all the speakers, dump the sub. Rebuild what should be there in the first place. Verify manufacturers connections and your interpretation of said, in the harness. Verify that the radio or amp can handle a sub without some goofy mono marriage of rear channels to obtain required ohms for crappy walmart sub Bazooka.
On second thought go to best buy, apply for credit card, and tell them that you want to bump down the road.
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
I bought a cd player for my 94 grand cherokee and bought a wiring harness for the speakers. And. I want to kno which colors are the speaker wires
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Dec 11, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
The radio in my jeep isn't connected right. Some of the wires have come apart. i bought new **** connectors but how do i know which wires go together?
Thank you for using Fixya and good luck
Mar 22, 2010 | 1994 Jeep Grand Cherokee
How to hook up a kenwood car sterio in a 1992 saturn sl2 car.my radio was stolen and a bought a kenwood and we dont have the color codes for wiring them together
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Rear Speakers Size: 6 1/2′
Feb 06, 2010 | Car Audio & Video
Stereo wiring diagram
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 15, 2009 | 1999 GMC Sierra
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
2002 Chrysler Town & Country - Driver Front Dash Speaker Buzzes
The first thing I would do is pull the stereo out of the dash and unplug it . If the buzzing stops the stereo is bad get a new stereo. Its not hard to remove the stereo. Right above the cup holder there is a small cover you need a very small screwdriver to remove it . Under that is a few screws take those out then grab the plastic cover that runs around the stereo and pull towards the back window it simply pops off (No screws) After you remove that cover you will see 4 phillips head screws that hold the stereo in remove them. Last slide out the stereo there will be 1 plug with alot of wires that is the power and speakers . Unplug it . The other round plug is the FM antenna
Mar 26, 2009 | 2002 Chrysler Town & Country
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Ground Wire: Gray
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
