I plug it in and it shows its plugged in but when i turn it on it makes this buzzing nois and then turns on and off super fast. and just keeps making a buzzing noise
  • 1,606 Answers
That sounds like it has a problem with the power supply section. You'll need to find the authourized repair depot for your make and model, get a estimate from them (don't forget to add in shipping etc) Then see if you can find a local tv repair shop to give you an estimate. Next find out what a new replacement tv would cost. That will give you some numbers to figure out if it is worth fixing. Generally the newer/bigger it is the better chance its worth fixing. The buzzing could be capacitors or other parts in the power section. Some shops will be able to just replace these and others will want to change the entire board out (more $$) which is why you want as many estimates as you can get. If the repair price gets too close to the new price then don;t try to save a few dollars get the new one. The old may have other problems that will show up and a new tv has a warrenty.
Posted on Jul 31, 2010
I have a problem with the hands on Buzz. The hands were moving fast, but all of a sudden it moved slow. How can I make the hands move fast?
To make the arms move faster, remove all the batteries and the batteries on the remote control.
Buy brand new batteries and insert them in. Turn buzz to TRY ME on his back. Stand him up and turn him OFF for 5 seconds. Then turn him to PLAY and the arm will move faster.
/uploads/images/8_4_2014_7_01_51_pm.jpg
Jul 05, 2014 | Disney Pre-Order Ultimate Programmable...
Amp buzzes all the time
Make sure the ground plug is not cut off of power plug. Also, if the power switch moves in 2 directions, it is a ground reverse, meaning switch it the other way. If it doesn't, look for a ground reverse switch somewhere on the back.
Mar 05, 2013 | Music
Relay makes buzzing noies
This is usually a sign that the contact points in the Relay are bad and the Relay needs replacement. Another problem can be the wiring to the Relay no longer connects a terminal to the Relay. The Relay would not lock or stay engaged and the Coil inside the Relay would buzz because it can not connect and engage the magnets inside the Relay coil.
Mar 02, 2013 | 1997 Ford F150 Regular Cab
2I hear my own vois and a lot off nois in the 2handsets
make sure phones are turned off then plug it in...if it still happens replace the cable from wall to phone...the negative lead is bad
Jan 04, 2012 | Lands Phones
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
Turns over but will not start. Tried fuel cut off switch but no go. It has gas in tank, doesn't sound like it going to die just keeps cranking over but not "firing up" Ignition coil? Distributor...
First make sure your actually getting spark. Remove a plug wire and install a plug in it and ground it. Crank the engine over and look for spark. Next make sure your fuel pump is working the way it should. Turn the key to on and check and make sure you hear the fuel pump buzz for a couple seconds and shut off. If there is no spark then the ignition module mounted on the side of the distributor will need to be replaced. No fuel then you will have to replace the fuel pump.
Apr 12, 2011 | Ford Escort Cars & Trucks
Makes thumping noies under cab when goind down the
have the transmission mount checked or the cross member bolts to make sur they are tight
Nov 19, 2009 | 2003 Ford F250 Super Duty Crew Cab
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
2005 f350 that sometimes starts.Problem seems to
This is a diesel I assume.
Before anything else, you have to find out if it is a fuel delivery problem or a glow plug problem or, are your batteries tired? (Not cranking fast enough) Batteries have to be replaced every 3-5 years on a diesel.
1) Check your lift pump. It brings the fuel to the injection pump. It should make a buzzing noise when working. (You can feel the vibration if you put your hand on it.) It should buzz as soon as the key is turned to the on position without having to crank the engine.)
2) Check glow plugs. If the wait light only goes on for two seconds, then your glow plugs are burning out. (The wait light usually is on for at least ten seconds. Longer if it's really cold.)
3) Or the injection pump itself is weak. (Hopefully it's not this, as it can be very expensive to replace. We only want to do this as a last resort.)
Let me know
Oct 07, 2009 | 2005 Ford F 350 Super Duty
Sharp 65dr650 rear projection tv makes loud nois while its on
Looks like we all got screwed with this TV. Mine just started after 2 years and now it's getting louder. I think I rather call my lawyer than Tech. This product is NOT build properly and someone should let the company know about it.
Jan 04, 2008 | Sharp 65DR650 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
