Question about Bosch Drills
I bought a GSB 10 RE Kit. I am not able to differentiate between wooden drill bit, metal drill bit and concrete drill bit. Please help
  • 700 Answers
That is easy, drill bits have different angle on the starting end, often have little protruding screw and you can have virtually any possible type in existence pictures in this link:
http://www.google.com.au/images?q=wood+drill+bits&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&source=univ&ei=PNRTTMLtHYHZcY6_rMAM&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CEUQsAQwAw&biw=1280&bih=831
and in short explanation here:
http://www.diydata.com/tool/drillbits/drillbits.php
your metal bits are available here:
http://www.google.com.au/images?um=1&hl=en&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&biw=1280&bih=831&tbs=isch%3A1&sa=1&q=metal+drill+bits&btnG=Search&aq=f&aqi=&aql=&oq=&gs_rfai=
and in bit more info here:
http://www.thesitebox.com/Category/4141/metal-drill-bits.aspx
masonry bits in pix:
http://www.google.com.au/images?um=1&hl=en&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&biw=1280&bih=831&tbs=isch%3A1&sa=1&q=masonry+drill+bits&aq=f&aqi=g1&aql=&oq=&gs_rfai=
in bosh catalogue you have this picture:
http://www.bosch-do-it.com.au/bosch-do-it.com.au/diy/diyknowledge/tipsandtricks/7891/tipsandtricks.shtml
from left: wood, metal, masonry
welcome to my world :-) i hope you like your advice, if you find it helpful, please leave feedback for me, thanx!
Posted on Jul 31, 2010
Can you recommend the best site that offers reliable drilling tools at reasonable rates?
As there are a number of sites that offer drilling tools, it becomes difficult to choose the best one for you. I also wanted to boy one drill bit tool to be drilled into the concrete. I was wondering which drill bit would be most appropriate for this purpose. One of my friends recommended me to use masonry bits as they are suitable to be drilled into the concrete smoothly. You also need to find the right tool based on the material to be drilled on! Check the latest drill bit tools at Best Masonry Drill Bits.
Apr 16, 2018 | Best Computers & Internet
What drill bit to I use to make a hole in the wall of an old fibro house
FOR CONCRETE, CONCRETE BIT WOOD OR DRYWALL USE OTHER BITS
Feb 18, 2015 | Drills
How to repair cracks in concrete floors of house and how to make them waterproof
simply chip the conrete cracked maybe up to 3cm wide and 2-3 cm deep the whole way and clean thoroughlly with water and the best is to blow air after you wash with water to take away the loose debris then apply concrete epoxy arround the cracks with clean paint brush # 1-2 let it stay for about 30mins and you feel the epoxy is starting to set before then pour the conrete mix with fine sand that will do the trick.
Nov 05, 2013 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
I have drilled a 1 inch hole in my concrete basement wall. I cannot release the bit from the drill. The chuck won't turn by hand to release the bit.
Good Afternoon, Ladooudep55:
I hope you have got your bit back, but if not, remount the drill chuch onto the bit, and drill in forward without pushing the bit. If it still won't move, You can gently wobble the drill to enlarge the hole and retrieve the bit.
The other method is alternating light hammer taps with compressed air. It will make lots of grit dust.
If the hole around the bit is wet, you may have drilled into an iron pipe, if it smells it was the sewer drain. You will have to decide if you want to replace the pipe section or run an epoxy patch once you have retrieved the bit.
Chr
May 01, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
Drill chuck is frozen
You may try to put a thick soft metal pipe (aluminium or copper) over the drill bit (longer than the bit itself by ~10 mm) so it will touch the chuck's jaws, then GENTLY hit the other end of the pipe with a hammer several times, holding the pipe a bit askew, thus trying to disengage the jaws from the lock in their thread, and try to loosen the chuck after each series of hits. Just be careful with your fingers, and better hold the drill by the chuck while hammering it - so the hits won't go to the transmission unit (sorry for description - hope it's understandable, if not - ask for clafication from me)
Apr 26, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
When drilling in precast concrete, Does it take a special concrete bit?
It depends on what kind of fastener you are going to use, a split bolt is different that an ancor bolt and the need different size holes. so tell us the type of anchor bolt your using.
Jan 05, 2010 | Hammer Set Of 4 Hilti Concrete Drill Bits...
BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Nov 25, 2008 | Bosch 11236VS Rotary Hammer
BOSCH HC8531 CORE BIT
no u dont need water when drilling into concrete with a concrete bit.
Nov 17, 2008 | Drills
Drills Logo
830 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
