Question about Cameras
The power turns on but the shutter door will not open or extend, it prompts to turn off the power and turn power back on. I am able to see the photos thru the home button already taken that are stored on the card and do the other functions, but am unable to shoot new pictures because the shutter door remains closed. You can hear it trying to open but it will not.
  • 1,606 Answers
Usually when you see this either the shutter cover motor has a problem or the cover is jammed. You can try gently helping the cover open but don't force it.
You haven't mentioned the camera model so I can only give you some generic advice here. Basically on a lower cost camera the cost to repair is more than just buying a new camera. Even with a mid price range camera you need to be careful with the cost of this type of repair. So the first thing you want to check is if you have any warrenty. This is covered. Some brands will offer a flat fee that fixes the camera regardless of whats wrong. Usually its around $120 or so. Next you want to check on the replacement cost. A newer camera may actually be cheaper than getting your old one fixed. And it should have better resolution and other feature as well. When you know those then you can deceide if it is worth fixing or to just replace.
Posted on Jul 31, 2010
  • rcraft5090 Jul 31, 2010
    It is a cyber-shot 8.1 pixels, optical zoom 5X , Full HD 1080 still image, smile shutter, super steady shot +ISO plus 3200 - it was a gift so I do not know the cost - so do not know if it would be better to buy a new one or fix........
    what is the comparison?
    I am able to open the shutter "doors" easily but it will not extend - so it may very well be the motor as you stated.
    I was using it fine on one shot and then it stopped working the next time I went to use it - did not drop it or anything.
    It is 1 1/2 years old.
    DSC-W150 Super Steady Shot by Sony Cyber-Shot
Will not display even there is power
When you turn on the camera and the lens extends, there is a small protective shutter on the outside of the lens that should open. Turn the camea around and look into the lens. Did the protective shutter open?
If not, give it a little nudge. Sometimes they can stick. If it doesn't open, or if it does/is open and there is still nothing on the display, then there is probably a more serious problem internally.
Hope this helps
Randy
Dec 01, 2012 | Canon Power Shot SX210 IS Digital Photo...
Door latch
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
How to disassemble lens on a casio exilim ex-z75
Jim, I really wouldn't recommend this. It requires extreme patience and meticulous parts tracking. Note that junctions stated: "It's really hard to take apart,", and he ain't kidding.
Really recommend that you return to the remedies that you had been trying. Sometimes it requires many repeated tries to free the gunk from the shutter. I've found that for the smaller pocket cameras that the most effective solution seems to be extending the lens and tapping around the lens barrel with a pen/pencil. Then alternately opening the battery door with the camera turned on (no need to play with shutter modes). Then just alternate with tapping, battery door, tapping, battery door, and keep doing this until the shutter opens/closes. Once this happens, set the camera to continuous shutter mode and snap off about 100 pictures to final lubricate the shutter.Good Luck,t00nz aka CR
Nov 22, 2011 | Casio Exilim EX-Z750 Digital Camera
Shutter is stuck. when I turn the camera on the
Have you tried to gently coax it open with something like a toothpick?
Jun 13, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
Lens will not extend
Hi:
You need to clean around the lense first. Blow high pressure air spray and get the most sand out of the lense you possibly can.
If it did not open 100%, try to pull it out NOT too hard. If the lese goes up and down and turns you should follow the lense while pulling it out.
When it is 100% out, (the way normally opens) Clean around the lense more.
Turn you camera on and off a few times. It should be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 20, 2009 | Konica Minolta DiMAGE G500 Digital Camera
DSC-W80 zoom extends, shutter opens, closes, zoom closes, 5x, won't work
Hey kbcinc,
I would try taking the battery out and waiting a minute and then reinserting the battery. Another option you have is to try and reinitialize the camera, but you would need access to the settings menu on the camera and it doesen't sound like you do. To initialize the camera go to main settings 1 and choose initialize. If this doesn't work I would bring it to an authorized service center to have it looked at.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 11, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Outside shutter cover will not open
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Mar 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Shutter does not open
The camera does not gets opened on power on it seems that some gear has broken inside
Feb 27, 2008 | Samsung Digimax A400 Digital Camera
Shutter door does not open automatically
Hello, just recently ran into the same problem. What is the best way to get spring out of there. Slight manual pressure isn't working.
May 06, 2007 | Canon PowerShot A520 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
