Question about LG GSA-2166D DVD RW Dual Layer Burner
How long does it take to burn a 2 hour movie? I have 512 MG DDR SDRAM with 3200+ AMD Athlon XP Processor.
  • LG Master
  • 1,606 Answers
That will depend a bit on the speed of the dvd drive and the media speed. Basically should take about 30-40 minutes. On a faster drive it should take about 25. A 2 hour movie should almost fill a dvd 4.7gb in size. Those times are for a internal burner not a external usb burner.
A dual layer dvd should take twice as long but from my experience it doesn;t seemt to take more than a few minutes longer than a normal dvd which is strange but nice.
Make sure you have lots of space on C and try not to be running anything other than the burner software to max out on the speed. And don't worry if you toast a few dvd's at first. They are cheap.
Posted on Jul 31, 2010
I have the hp pavilion 524w desktop computer and I was wanting to know if it is possible to insert a newer version of the processor. 1.73 ghz is not fast enough. Is there anything faster that will go with...
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29
So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Aug 04, 2011 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
How do you know when a memory stick is single-bank? I want to upgrade my A7V8X-X with 3 Gs, but I keep getting confuse how to determent what is single-bank! Is there a specific code in the product...
This is the memory spec for your motherboard...
3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Part of the memory spec will tell you if it is single sided (memory chips only on one side of board)
Double sided is memory chips on both sides of the board....Some systems will not work with double sided memory...
Feb 10, 2011 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
Swapped in 2 ddr 512 266mhz sticks for, 2 sdram 512 133mhz sticks. no boot, only beeps, neither sticks will work in either slots. cpu has a athlon xp 2000 133mhz processor, is this the problem? Do I need a...
Your motherboard works only with 100 or 133 MHz memory modules.
You hear the beeps because the motherboard is telling you that the memory is not compatible with the board.
The processor is not the problem.
Don't forget to rate this answer if it helps
Dec 05, 2009 | EliteGroup K7VMM Motherboard
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I have an Elitegroup KT600-A motherboard (System model KT600 8236) manufatcturer VIA Technologies, Inc. with total physical memormy 640K. Processor is x86 Family 6 Model 4 Stepping 2 Authentic AMD ~998...
Hello, according to your boards manual page 38 you will have to use unbuffered memory (non-ecc) and depending on which OS your are gonna use, it might address up to 3 GBs of (SDRAM) my personal preferrence is 3x1 GBs with XP Pro 32 bits. The CPU you mentioned should work just fine, and with the added memory your rig should provide you better performance, hope this little bit of info helps.
May 09, 2009 | Intel Desktop Board D845GLVA...
Which memory can i use?
I should think that will be ok but why restrict it to 512 when you can have 1024 mb
Feb 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
LG GSA-2166D DVD RW Dual Layer Burner Logo
49 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
