Question about Microsoft Xbox Console
Xbox malfuction help me! my xbox needs u. i got a disk and i press eject to try and get it out but the stays in there but still the disk tray opens but with no disk.
  • 45 Answers
Wow. Try to look inside the drive to find it. If you can find it whole. If you can, grab it with 2 q-tips or something. If it is in shards, there's nothing i can do about it.
Posted on Aug 18, 2008
XBOX360 disk tray keeps ejecting
This is likely the same issue occurring when the disk tray will not open either. Suspect your drive belt is worn and requires servicing. This is best done by an xbox servicing agent. Not too expensive. I have been suffering with a tray that will not open for over 2 years now, however, I am able to fix it simply by ensuring a disk is always left in the tray. It only fails to open if there is no disk in the tray. Even then, I can open it by lifting slightly with a paperclip.
Jul 18, 2014 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
I went to put a game in the xbox to play,I waited for it to load & nothing happened.The screen said open tray.I waited & waited but nothing.I pressed the green button on the controller but the tray...
Well you may be having disk tray issues, sure hope so as compared to a burnt out lens module,try ejecting the tray fully and wiping all dust off around the grooves under the tray,one more tip is to keep a disk in the drive at all times, even when you aint playing it, you can also try giving it a gentle tap on the front pat where the disk tray is located any time you eject it or push the tray back in, come to think about it if you are fond of pushing the tray in after inserting a disc, stop cos it weakens the motor that drives the ejecting process, hope this helps...
Oct 25, 2010 | Microsoft Xbox 360 Console
My xbox disc tray is not ejecting
If you lay your console flat press eject, then give the console a few raps (dont go mad) with your knuckles where the centre of the disk should be the draw will open.
let us know if this solution helps.
Jan 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 cdrom won't keep
turn on your 360 and open the game drive. hold it open and turn of the 360. wait for it to power down completly. then turn the consel back on and it should close on its own now and stay closed as it should
Jan 07, 2010 | Video Game Consoles & Games
Xbox 360 disk spins while ejecting
i had this same problem, so i figured, "what the hell?" i might as well open the dvd drive up and clean it out. so i looked for how to video for taking apart my 360 and opening the dvd drive on you tube( this voids your warantee of course) and i cleaned all the dust out with compressed air and swabs dipped in alchohol. this worked for me so i hope it works for you.
Oct 22, 2008 | Microsoft Xbox 360 Console
Disk tray won't open
Call Customer Support: 1-800-4MY-XBOX
Dec 06, 2007 | Microsoft Xbox 360 Console
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
