Question about Sony Playstation 3 (PS3) Console
No picture and the audio video cable is connected joelgoodenough@hotmail.com
    President:
  • 1,139 Answers
Try resetting the vieo back to standard definition by holding the power button down for 5 secods.
Hope this helps
Posted on Jul 31, 2010
Testimonial: "worked very well. Now just trying to get it to load a new game of disk"
    Sergeant:
    Champion:
  • 297 Answers
Looks like you have that problem sorted but to fix the game reading problem you will need to readjust the laser.
It can come off key and is quite easy to fix from home either check out these repair guide reviews or you can send it in and get it fixed.
The DVD will go in but the picture is black and yo can hear but the picture out
Usually DVD players have audio and picture "out" connections to go to your TV. Verify that your cables are connected. If it has worked in the past and suddenly started, disconnect then reconnect the cables at both the DVD player and TV end. Cables do not usually go bad but unfortunately DVD players are considered disposable and are not usually repaired any more. If you have multiple video/audio connections on the back of your TV (like Video 1 & Video 2) switch the cables from one to the other. Be sure to keep your cable sets together and don't do something like video output to video 1 and audio output to audio 2. If that works for you then you may have connectors on the back of your TV going out. Hope this helps you.
Nov 07, 2017 | Televison & Video
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
My new PS3 wont seem to connect to either audio or video connections? is there a general problem with this tv model? i tried both the R/L audio's and for the yellow cable i tried that in all of the...
Sometime the game cable connections itself have bad conductivity and shorted,tries twist and shake the cable u hear humming audio and see flashes of picture in and out?Tries hook it up with a single HDMI cable cord,have a more success with many LCD tvs models.U have a HDMI cable or try Ebay.com,Amazon.com to buy one.
Jun 01, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Need owners manual for proper connections to tv w/direct connections I hsve a sony dvp ns300 cd/dvd player
The connection you use will depend on the TV. For the best picture, connect component video cables (not included) from the DVD player's output (to the right of the other jacks on the back of the unit) to the component video in of the TV. Then connect the Right and Left audio from output 1 to the appropriate audio input of the TV. (These may vary depending on the TV and other devices connected to the TV. They might be audio 1 or part of a group with the component video inputs.)
Otherwise you can use an S-video cable connection and the separate audio cable or the composite video cable (which has 1 yellow RCA plug for video and 2 others (red and white) for audio). Connect these from the output of the player to the matching input ports of the TV.
For TVs with only RF in, you need a composite video to RF modulator (converter). See a store like Radio Shack for this.
The manual is available from Sony: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPNS300 . Pictures of the connections start at page 15 and more detail is provided from page 17 through 23. See the manual for details if you have a home theater system or other external speaker option.
I hope this helps.
Dec 08, 2010 | Sony DVP-NS300 DVD Player
@hotmail.comsir i got panasonic nv-fj620b-k vcr, when i connect vcr with tv i have only audio not video, kindly let me know which type of cable i may use to get connected properly regards
Depends how you are connecting at the present. If you use a Scart, make certain it's a good one as the pins are easily damaged and can cause loss of picture.
Dec 01, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Apr 06, 2010 | Harman Kardon AVR 135 Receiver
I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Jul 12, 2009 | Sony STR-DG520 Receiver
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
JVC ax-r441
Red = right audio
White = Left audio
yellow = video ( do not connect if your amp doesnt have any video inputs.)
Jango.
Feb 24, 2008 | Audio Players & Recorders
Xbox 360 video and audio
Hey mate, check to see if the cables are connected to back of the TV correctly, try another TV if you are able too.
How are you connecting the xbox 360? try using the scart cable, see if you have a picture.
Report back with your findings,
Hope it helps
Z33m
Dec 10, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
114 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
