I turned on the new DVD and did not wait for it to go through it's thing before turning it off and now it wont start. hat do I do?
    Master:
  • 377 Answers
Can you please give the the maker & the brand / model..
Thanks
Posted on Apr 24, 2008
  • 19,396 Answers
Try disconnecting powr cable from outlet for a while
1996 Chevy Lumina wont start. Relay fuse on passenger side under hood clicks. tried replacing it, wont start. but if you wait 8 hours, a day or two, and try, it fires fine??? The only time it wont run is...
Could be several things....but i need more information. When it doesnt start, does it crank or when u turn the nothing at happens other than the relay?
Feb 04, 2010 | 1996 Chevrolet Lumina Mini
Blue hat metal detector doesn't work
We are having the exact same problem. Looks like we either got a dud or the thing is a piece of junk.
Dec 25, 2009 | Blue Hat Teach and Talk Activity Laptop
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
Problems starting up my LG RH188H
I had the same problem. After googling I found that the HDD might be faulty so I unplugged the device, brought it upstairs to unscrew it (to change the HDD for an empty new one). One last check before I really unscrewed the cover - and the recorder started again! After 5 minutes the 'please wait' returned. So, did the same thing again, tried a few times, and the recorder started. Then, I imediately reformatted the HDD, and the problem is now gone.
May 23, 2009 | LG RH188
Car wont start
Try this Put your key in turn it on dont start wait 10 mins remove key wait 10 seconds repeat this a total of 3 times. If that dont work try a different key do the same thing. If that dont work a dealer needs to probably replace and reprogram your ignition switch and keys
Apr 06, 2009 | 2005 Chevrolet TrailBlazer
1999 Chevy S10 cranks but wont start
A very common problem on the 99 S10 is a leaky fuel pressure regulator in the intake plenum.What happens is when the truck sits for a few hours or more the regulator leaks all of the fuel in the fuel injection system into the intake air plenum. This does 2 things, 1 it has no fuel pressure when starting and 2 it floods the air intake with raw fuel. Sometimes if you turn the key on wait 3 seconds then turn key off then turn key back on and just turn key to crank starter for a split second and wait 3 seconds.do this 3 times to repressurize fuel system then crank to start(you will hear fuel pump buzz each time you do this.also you may have leaky fuel injectors. Try to crank engine with the gas pedel to the floor. This will tell the computer to stop spraying fuel trhough the injectors and it will start. Joe ASE Master Tech
Mar 04, 2009 | 1999 Chevrolet S-10 Pickup
Samsung DVD/HDD
Greetings guisey,
I would suggest unplugging the unit for a few minutes then allowing it to intialize again. Don't skip the program this time though. :)
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 24, 2008 | Televison & Video
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Akai LCT2721AD 27 in. LCD
sounds like the pwr supply is suspect....
Oct 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Please wait
try to clean loading sensors
Jun 03, 2007 | LG RH-4820 DVD Recorder
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
