Question about Zanussi FLE1416W Front Load Washer
Zanussi fle1416w aquacycle 1400 xc , on some cycles it does not take in any water into the drum although water goes into the draw, clothes are totally dry at the end. Some times it keeps pausing and beeping waiting to be restarted. I can't see why this has started to happen, could you please advise me what has happened . Yours sincerely ATurner renruta@hotmail.co.uk
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Check drain hose has not dropped down. that the height of the waste pipe is at least 50 cm high and the waste hose has not been pushed a long way down the stand pipe. all these things can cause the machine to syphon out all the water it has taken in. it more **** to happen on delicate programs with higher water level the beeping would happen after 5mins. comment back if this not the case
Posted on Aug 03, 2010
Zanussi aquacycle 400
all washers have water level sensors and most of them are fitted with water level via filling a tube with water the switch is activated telling the machine to turn off the water
most of the time the tube gets clogged up with soaps etc.,
clean the tube and check the operational of the switch .
Nov 24, 2017 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Having a new floor in the kitchen and my faithfull
Buy a machine that will is the first thought , otherwise get the kitchen fitter to raise the worktops above the washer
You could try taking off the top lid and removing the feet underneath which will give you some room
Make sure that you place a sheet of plastic over the top of the machine from side to side and tape it in place if you do remove the top
That is in case you spill anything on the worktop which then drips inside the machine
Sep 16, 2009 | Zanussi FLE1416W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
I need instructions for zanussi aquacycle 1400 XC
My washing machine dials won't light up and strait but the power is switched on
Jul 03, 2009 | Zanussi F1245W Front Load Washer
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Zanussi FLE1416W Front Load Washer Logo
501 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
