Question about Olevia 237T 37 in. LCD TV
Yesterday, I powered on my Olevia tv and I had a strange purple screen and no picture so I turned it off. When I turned it back on, I had no picture. So now, the blue standby light is on, but when I try to power it on, the standby light turns off, but I get no picture. After about 10 seconds, the blue standby light comes back on. I've tried leaving in unplugged for 24+ hours with no success. Any suggestions as to the next step I might take to see if there is anything I can do. Thanks.
  • 712 Answers
This one is a common problem for L.C.D screens. 6 screws that attach the inverter board to the LCD gray metal bottom loosen over time, causing the TV to periodically lose video while retaining audio. Sometimes turning the TV off and on again restores video, sometimes not. The problem gradually gets worse making the TV unusable.
To fix it yourself is a time consuming and difficult task, although you need no additional devices to be replaced. The disassembly and assembly may eat a lot of your time. But if you are still interested get yourself a service manual (must have came with the t.v or you may download it) and follow the disassembly instructions given in it. Go through the following steps: Stand Disassembly, Back Cabinet Disassembly, Angle Back Disassembly and LCD Cover Disassembly.
Once the LCD cover is removed, on the left side you can see the metal cover of the inverter board and the six screws holding it down, the very screws that we have been looking for! Remove the six screws and the metal cover. Without disconnecting any of its connections, rotate the inverter board up and to the left to expose the bottom of the inverter board as well as the gray metal bottom of the LCD to which the inverter board is attached and grounded. Note the 3 copper rectangles on the bottom of the inverter board surrounding the 3 screw holes away from the left edge towards the middle of the TV. These are the grounding strips that lose their connection.
Using contact cleaner clean off any black burn marks from these connectors. Also clean all black marks from the grey metal bottom that they contact. Clean carefully and thoroughly. You might need to scrape lightly to remove all marks.
Rotate the inverter board back in place. Line up the metal inverter board cover. You can either use the 6 existing screws or purchase replacement screws (only if you are not satisfied with the old ones). Using a removable thread locker coat the screw threads of one screw. Tightly screw in the middle edge screw first. Follow this by the edge top and bottom screws, then the middle inner screw, and finally the top and bottom inner screws, using the threadlocker on all 6 screws. Verify that all screws are tight.
Now start the reassembly in the reverse order of your disassembly. If you have done everything fine, you can find your t.v working fine.
Best Regards. Thank You.
Posted on Jul 31, 2010
I cant get it to work on full screen
I am having this same problem as this one above (62HM95). The issue I'm having is that it will also not work full screen. I selected the 'Split' option on the remote and the picture on the left is fine... absolutely clean and perfect, with audio. The picture on the right is completely distorted in very strange colors (mostly constant variations of purple), with audio as well. You should note, that the same video information was feed into different imputes to select for the split. In other words, I feed the cable stream into the TV using the component video (Y B R) as well as the coaxial cable and selected both options for the purposes of displaying the same information side-by-side. On screen I selected video option four (4 for color stream HD) and option (0 for cable/antenna). If I highlight either side and select one of them (4 or 0) the screen goes full screen and I see nothing but one solid color of purple. I've researched the purple and they call it 'Electric Purple'. That is all I see... just the solid purple, with the audio. What I have also noticed is that, If toggle between imputes while in the full screen option and come back to either option (4 or 0) the image plays/appears OK for about 2 seconds then goes back to solid purple. I just can't understand why this is happening especially when the on-screen menu displays perfectly fine. I cannot enjoy this TV by only watching half of it in split mode. Besides the multiple replacement bulbs I've had to buy I've completely had it with this TV
May 29, 2012 | Toshiba 62HM95 62" HDTV
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Mar 06, 2010 | Televison & Video
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Olevia 37 lcdtv has to warm up be repowere for picture to display
It's your power supply. have it taken care of ASAP before damage happens on the board where it can't be repaired, just replaced, "if they can find one".
Jul 15, 2009 | Olevia 237T 37 in. LCD TV
Power supply problem?
necesito comprar la fuente de alimentacion electrica de mi tv olevia lt37hvs mi correo es luis19rpm@hotmail.com
Sep 01, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237T 37 in. LCD TV Logo
87 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
