Question about Kodak EasyShare C643 Digital Camera
Neil has a problem
When i turn my camera on my yellow light flashes and my camera does not go on .(is it my battery?)
    Novelist:
    Champion:
  • 216 Answers
Greetings killo1975,
Generally this does indicate battery failure. At the least, I would recommend changing your batteries and see if this fixes the problem.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on Apr 24, 2008
Tip
Samsung SL202 Flashing Yellow Light Is your Samsung SL202 flashing a yellow...
Is your Samsung SL202 flashing a yellow light and not charging its battery?
This is an indication that your camera has decided it needs to completely discharge its battery before the charge cycle begins it again.
Rechargeable batteries last longer and perform better when they are completely discharged before being recharged. This is normal.
I hope that helps.
______________________________
SL202 User Manual here.
SL202 QuickStart Manual here.
on Apr 18, 2010 | Samsung SL202 Digital Camera
HI i HAVE A SONY DSC W55 camera. My Flash light on the camera is not working. When I click a picture with flashlight ON, a yellow light just on top right side of the display turns on steady. Once the...
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances: When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode If an external flash is connected. Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Jan 16, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
May 24, 2010 | Jet 3 Ultra Power Chair
Not powering up and batteries are good. the little blue print light was blink at some . that was the only sigh of power at the camera. Neil
Suffering the same problem Neil. Tried removing cmos battery, no joy....tried 3 different batteries, with and without grip, still no joy.
Anyone got any ideas before i book it into camera hospital?
Cheers,
Al
Aug 04, 2009 | Canon EOS 40D Digital Camera
Flash stoped working
Make sure yor flash is turned on. You might have burnt out flash bulbs.
Apr 16, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Flash Indicator light
it´s a normal problem on the cameras, but to be fixed u will need to send it to a service centre, because it needs a board to be replaced.
Jan 15, 2007 | Olympus Camedia C-350 Digital Camera
Kodak EasyShare C643 Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
