Question about Panasonic TH-42PX60U Television
I usually keep my screen settings in cinnematic mode at manufacturer's settings found online decided to change to vivid for use with wii when a black vertical line appeared on screen after unusual mild flickering like a light bulb = What could the cause ? I have had this model for 5-6- almost 7 years
  • 49 Answers
Change vide out put voltage capacitor ,check crt earth crt bace and crt
Posted on Jul 31, 2010
Cannot get my wii to connect to my charter wireless
To connect a Nintendo Wii to the Internet using a wireless connection, please follow the steps below:
  1. On the Wii console's main menu, click on the Wii button in the lower left corner.
  2. This will take you to the settings screen. Click 'Wii Settings'.
  3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the Internet button.
  4. Select 'Connection Settings'.
  5. Select an open connection, indicated by None.
  6. Select 'Wireless Connection'.
  7. Select 'Search for an Access Point'.
  8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search is completed, you will be directed to choose the Access Point that you wish to connect to, as shown. Click OK to display the list of available Access Points.
  9. Select your Access Point from the list of available Access Points. If your Access Point is not displayed, contact your wireless router manufacturer for support.
  10. Click Save followed by OK to save your connection settings.
If your connection appears as a closed padlock, then the Access Point requires a security code or pass phrase. The security code or pass phrase can usually be found on the security tab of your wireless router settings. If you do not know the security code or pass phrase and do not know how to login to your router to get it, contact your wireless router manufacturer for support.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal, contact your wireless router manufacturer for support.
If you still have problems, call them at: 1-888-438-2427.
Mar 28, 2011 | Video Game Consoles & Games
Connect our Wii to the internet to play multi player Black Ops??
You can connect the Wii to the internet, either through a wireless internet connection or by plugging a internet line directly into the rear port on the Wii. Once you are sure there is internet accessible to the Wii, there will be an option in the network settings of the Wii to set up the internet and any internet access information needed. once you have done that, simply feed your game disk into the disc drive on the console and it will load. select the multi-player game mode on the home screen of Black Ops and you will be allowed to play online, barring any parental controls preventing this.
Hope this helps =)
Feb 21, 2011 | Nintendo Video Game Consoles & Games
My Samsung DLP HD tv's picture is starting to go dim. What can I do to make the picture bright like it used to be. Model Code - HLS6187WX Thank you for any help you can provide. Spencer
Has the lamp ever been replaced? As lamps age they get darker screens. First though check to make sure the TV settings aren't accidentally on a dark setting. Go into the menu and see if increasing the brightness helps.Different picture modes like movie, games, vivid have different brightness settings vivid usually the brightest.
Sep 11, 2010 | Samsung Televison & Video
I have a nintendo wii try to go online and keep getting an error code 51030
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Dec 05, 2009 | Nintendo Wii Console
Best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Nov 09, 2009 | Samsung LE40M91B 40 in. LCD TV
Monitor Mag innovision 796PF. 30% more Black screen
This sounds more to me like you are experiencing problem with your video adapter than the monitor itself. Have you tried a different video card? If you have onboard graphics, you may have to disable it in BIOS inorder to install a new graphics card. Monitors usually either work or they don't. If it requires you to change modes and readjust resolution, it is probably the video card.
Jul 10, 2009 | Computers & Internet
Wii cant play the game
Hi . i have had this sorta problem when i play the resident evil game. I find that if you go to your menu on your startup screen and change the screen resolution it should work. some games require certain television res to allow play.
Feb 28, 2008 | Nintendo Wii Console
Wii Black Screen
i put the wii on, powers up but i get a total black screen. wiimote does not connect either. what can i do to resolve this?
i have already disconnected all wires and connections, left it off for hours and tried putting it on again. no change. Black screen still remains. HELPPPP
Dec 01, 2007 | Nintendo Wii Console
Wii black screen
The following fix should help users who do have problems with some virtual console games for the Nintendo Wii that display only a black screen after starting them while the sound remains normal. This does not work in all occasions but should work if you get the Wii menu when you press Home and works only for games that received an update for the interlaced mode.
Try out the following to see if this fixes the issue. Start the game normally until you see the black screen. Connect the Nunchuck to the Wiimote and press Home to see the menu options. Now press A + 2 + Z together which should result in a short “ping-like” sound.
This should have activated the interlaced mode. Leave the menu and you should see the normal game screen and not the black screen anymore. To change the mode again press A + 1 + Z using the same method as above
Nov 20, 2007 | Nintendo Wii Console
What is the color mode? Can it be selected in the movie recording?
With P, A, S, M, mode, (set using the exposure mode dial) the following four modes can be selected to suite the image. Vivid color is to be selected to produce more vivid image than the natural colored image (default), Black and white is to produce monochrome image in black and white, and Sepia is to be if it should be the sepia tone. Also, they can be selected in the movie recording.*The color mode of the saved images cannot be changed. They should be selected before recording. *Automatic Digital Subject Program and AUTO can not select them. (natural color only)
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Panasonic TH-42PX60U Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
