Question about Dishwashers
I have a Chef Classic dishwasher ( model B8913WW) which is no longer heating the water, I assume I need to replace the element but nobody in my area knows where to get parts for this make or model, any ideas please??
    Scholar:
  • 59 Answers
If you know how to use a multimeter you can get to the heater connections and check the resistance of the element. it chould be about 26 ohme. Also the over heat protector thermostat should measure zero ohms. Make sure all wires connected to the heater and thermostat are solid. There might be a broken wire in the door loom from the lom flexing or the controller may not be sending power to the heat circuit.These are the pissibilities. if you measure the wire coming to the heat circuit and no power comes then the controller is the problem. if the controller is electronic check thatb there arent any burn marks on the controller. If you fimd a poor soldered joimt on he controller you can solder it. good luck
Posted on Aug 01, 2010
Testimonial: "Thanks for that, I will give that a try, it will be good to check that stuff before rushing out and getting a new element which I may not even need."
Model DEDW645S dishwasher - no longer wil remove butter from knives or butter dish. How do I know if the heater element (if there is one) is no longer working? Other dishes was well.
There is no sensor to tell of the heating element is not working. The water should be heated to 50 - 60 C. You might want to interrupt it when it is washing to see what the temp is.
Feb 12, 2017 | Dishwashers
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Magic chef du4000v
You can install it on the cold water line. The dishwasher has its own heating element to heat the water.
Apr 06, 2014 | Magic Chef Dishwashers
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
Water temperature is not that hot any more dishes stay dirty after 3rd cycle
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Testing a heating element
Note: Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Use your multitester (aka multimeter) to test the heating element for continuity. Set the device to the ohms
setting x 1. Touch each meter probe to a terminal. You should receive a reading somewhere in between infinity and zero. Because of the variety of makes and models of dishwashers, it is quite difficult to say exactly what the reading should be for each and every possible model. However, if the test you conduct produces a reading of infinite resistance (meter's needle does not move), then that is indicative of a faulty heating element, and you should replace yours. Similarily, if the test you conduct produces a reading of zero resistance (meter's needle moves to the other extreme of the scale), then that is also indicative of a faulty heating element, and you should replace yours.
You do not have to remove the heating element from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Jun 13, 2011 | Dishwashers
My chef classic dishwasher is not completely cleaning the dishes. There is no obstruction to the tablet/powder door opening, although there is a small amount of powder left at the end of the cycle. Both...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Magic Chef CDB6100 Built-in Dishwasher
Water not heating therfore dishes not washing or drying right.
Well the water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Please follow the below steps to check the heating element in your dishwasher -
(Note.Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.)
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Dishwashers
The Superba dishwasher is not longer heating the water hot enough that the dishes will dry themselves.
Your dishwasher has a heating element that heats the water. If you will callor email us with the model number, we'll send the right element out fo roy u to insyall. They are very easy to replace. Hope this helps!
Oct 06, 2009 | Dishwashers
Frigidaire hot water problem
no, i don't think so. the heating element is located under the inside tub and out of the dish area. if you could supply me with the make and model #, I will try and find the exploded view for you. the element is replaceable.
Dec 11, 2008 | Dishwashers
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
