Question about BOSS AUDIO CAP3-5B 3.5 FARAD CAPACITOR, DIGITAL VOLTAGE
For some reason my capacitor wont charge, I've checked everything! I just bought a boss cap3.5b and I know for sure the fuse is working there is power coming from the battery and the cap is grounded correctly. But for some reason when I connect the resistor to the cable and to the cap nothing happens! The voltage meeter doesn't turn on at all and also doesn't flicker. What's wrong?
    Sergeant:
  • 170 Answers
Get a small led or something that runs on 12 volts. i use my 5 dollar 12v test light and hold it to the positive cable thats gonna be hooked to my cap.
hook the other side to the cap, it will light up the test light and in a minute or two the light dims and then goes out, after its out , the cap is charged......JUST DONT LET IT TOUCH THE OPPOSITE WIRE WHEN YOU HOOK IT UP OR YOU DISCHARGE IT and its not funny
Posted on Jul 31, 2010
My capacitor 35 farad doesnt charge
Posted on Aug 05, 2010
2 Suggested Answers
  • 55 Answers
SOURCE: 35 Farad hybrid power capacitor not charging
Yes you certainly wire the 12v+ wire directly to the positive post of the stiffening Capacitor, however if you have a one of those test light probes to check for current on a car? They are really cheap but what i do is clamp the one end on to the battery and than touch the probe to the + teriminal of your capacitor, when the light goes out your cap is fully charged. Now if the light does not go all the way out or stays on you have a bad capacitor, and might i ask why the hell are you driving to need a 35 Farad Capacitor anyway?? Damn.. We do show and competition cars here and sometimes use them. I like the BatCap way better, it's a Battery and a Capacitor all in one. Way strong like bull..... good luck... Mark
Posted on Aug 20, 2009
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
2000 olds alero 2.4 engine. charging system is not working. replaced alternator and still wont charge the battery.
Check the owners manual for the car and look at the fuses. Sometimes theres a fuse for the alternator. If everything is good there check and make sure the power wire going to the alternator is good. It should have battery voltage here.
Apr 25, 2011 | 2000 Oldsmobile Alero
My 20 farad boss capacitor lights up but dont display any volts even when i try to charge it and it suppose to..
OK this just happened to me an i tried something that might work for you all i did was disconnect the main power cord from the battery then double check your wire connections to your fuse then after your done checking the wire connect the power cord back to the battery then start your car up turn the radio on an your display volts should be there
Jul 24, 2010 | Boss Audio CAP10 10 Farad Digital...
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
My cruise control doesnt work
First check the brake switch if it is sending a signal that the brake is applied the cruse cont. wont work. If the vehicle is a standard then also check the switch on that pedal for the same reason. I don't really know what you mean by "the gas light" do you mean the light behind the gauge or?
May 08, 2009 | 2001 Toyota Tacoma
My insignia amp wont work
Try removing the capacitor and discharging it with a .5 watt (radio shack) light bulb, and then reconnecting it in the same fashion.(before hooking it back up to the amp place it in line with the capacitor until the cap reads 12v with a multimeter or capacitor display) The capacitor will conduct but not store a charge for the amp if not properly charged before making the amp/capacitor conection. and therefore shut down or not start at all.
Apr 30, 2009 | Insignia 1200W Class D Bridgeable Mono...
Dell w4201c burning fuse...
hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Jan 10, 2009 | Dell W4201C 42 in. Plasma HDTV
BOSS AUDIO CAP3-5B 3.5 FARAD CAPACITOR, DIGITAL VOLTAGE Logo
1,787 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
