Question about Hitachi 42HDT79 42 in. Plasma Television
I am getting message number H442; HDCP not supported. Running an HD cable from an HD Sky decoder
2 Suggested Answers
  • 226 Answers
SOURCE: I am running a Sky + HD box through my television
Hi, without a manual to hand, i don't know, but my Panasonic had the same problem, but I found somewhere in the settings, I could change it, it has something to do with AV and Digital TV and hdmi setup, give it a check.
I hope this helps to some degree, but give us a shout if you require more help.
Regards - Anthony
Posted on Feb 16, 2010
LG 37LC2D-EC
It sounds like the TV is having sync issues with your Sky+HD box. HDCP is the "High-bandwidth Digital Content Protection" that is used between components. It requires a sync between the devices to ensure that you are not trying to "steal" the video content you are watching. This intermittent message and blacking of the screen is good evidence that this is your problem.
Even though the HDMI cable worked fine on another set, I'd try a new one anyway. Some TVs and components are more sensitive than others, and a weakened cable may not show a problem on one set, yet show it on another.
Barring the new cable not working, check LG's website for a possible firmware update for your TV, and also try using a different video source, like BluRay and see you have the same problems.
Beyond that, it may just be an issue with the TV itself starting to die.
Sep 15, 2012 | LG 37LC2D Television
JVC Surround Sound System HDCP error message
HDCP...high definition copyright protection.
This means that one of two things have happened;
1) The connection method you used for video from the player to your monitor does not support the decoding of media that is copyright protected such as the Blu-ray format, or;
2) The media you are using is not a valid original recording.
As of yet, the only video connection available that supports the HDCP decoded signal is HDMI. Component video is capable of even greater resolution than HDMI but manufacturers haven't made a way of implementing it's use for copyright protected digital signals. However not ALL Blu-ray or HD-DVD media are copyright protected, that is completely dependent on individual title in which case a component video connection will work.
Dec 12, 2011 | JVC SP-PW100 Subwoofer
H442 Due to HDCP support not being detected on your TV this programme cannot be viewed
That means your TV does not support the copy protection being used on the video stream you are trying to watch. Unfortunately the only way around this is to use a TV that supports HDCP for that program.
Jun 28, 2011 | Televison & Video
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
Upgraded Sky+ to Sky +HD, but I now have a messages saying this display does not support HDCP?
Yes your tv is hdcp compliant.
This may not help but often when this message comes up it is the hdmi cable you are using. I do not know whether or not you are using an hdmi to dvi cable or an adaptor or and hdmi to hdmi connection. The cables available for purchase at beachaudio.com are not expensive but they usually work when you need to try another hdmi cable because of this particular message.
Mar 03, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Is there HDCP chip in Sony KF-E42A10?
HD programing 1080i,if tv it can get that mode.No part change in tv to get HD it can or not, that it.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Medion radeon x740xl can this show full hd on
It doesnt look like this card supports HDCP, which is required to decode HD content.
Nov 22, 2009 | Medion M3 Director 5100 PC Desktop
How do I get rid of error message across top of TV that reads "Your television cannot support HDCP video over your high definition connection (H1001)".
Use component cables instead of hdmi cables. I know this isn't the best solution, but HDCP is not used over component and the video quality is just about as good.
Jun 04, 2009 | Westinghouse SK-26H240S Television
Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Dec 06, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Hitachi 42HDT79 42 in. Plasma Television Logo
141 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
