Question about Eiki LC-XE10 Projector Multimedia Projector
Projector does not work with computer - Eiki LC-XE10 Projector Multimedia Projector
    President:
  • 567 Answers
Hi Connecting a laptop computer to an overhead projector is a relatively simple process. That said, it can be a disaster to work hard on a presentation, be it for a school or workplace environment, only to show up and find yourself unprepared. Take the time now to learn about the different ways your laptopprojector does not work with computer - mag-glass_10x10.gif can connect to an overhead projector, and how to accomplish this easy task, and you can enter your presentation with poise and confidence.
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Posted on Jul 31, 2010
  • 1 more comment
  • Hilton Bristol Jul 31, 2010
  • Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
  • Step 3Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
  • 4Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
  • Step 5.Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
  • Step 6.Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
    Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
    Why is my Sharp PG-D2510X Projector keep saying that there is no signal? It worked up until yesterday.
    Check both input selections on your computer and your projector. They both need to be set on the same input to work. For example, if the computer is set at 1080 and the projector is set on 720, it wont work. They need to match. Good luck!
    Apr 13, 2016 | Sharp PG-D2510X DLP Notevision Multimedia...
    Why is HDMI input not working?
    Apparently, HDMI cables can be finicky. You may have to try different ones to find something the projector "likes".
    Sep 01, 2015 | Optoma Pk320 Pk320 Pico Pocket Projector
    I changed my desktop background and now my projector will not display
    I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
    Jan 07, 2013 | Hitachi Office Equipment & Supplies
    Infocus 5000 won't recognize my computer
    How about a little more information?
    Does the projector turn on?
    has it ever worked?
    What type of interface (VGA, DVI, HDMI, RCA)
    What type of computer (notebook or desktop)
    That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
    Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
    Tutorial
    Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
    The projector will work as large screen projection monitor for the projector.
    If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
    Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
    When switching the projector from one computer to another the projector does not detect a signal from the 2nd computer. The projector previously worked with the 2nd computer. The projector model is...
    The second computer might not have the screen correct setup. If you have windows 7, simply push the windows button + p at the same time and it will bring up an array of options to connect a projector.
    Apr 10, 2011 | BenQ Office Equipment & Supplies
    Projector does not detect computer. Tried two computer and nothing. They both work great with the same video cable to the LCD.
    Since it is working on a separate LCD monitor, the problem is with the input settings on the projector. Make sure you have the correct RGB/VGA input selected on the projector. Also make sure you are not sending a resolution that is higher than what the projector can handle.
    Jan 27, 2011 | ViewSonic PJ558D DLP Projector
    Computer used to work with projector, and now doesn't?
    Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
    Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
    Jan 10, 2009 | Office Equipment & Supplies
    The projector has a blue screen. The projector will not connect with the computer. We are using this for a presentation and can't get the projector to work with the computer.
    Check all your connections to the computer then shut down the computer and restart. Try putting the setting on the remote to Computer setting. Also make sure the video setting are all correct in display on your menu.
    Nov 20, 2008 | Sanyo PLC XU35 Multimedia Projector
    Eiki LC-XE10 Projector Multimedia Projector Logo
    284 people viewed this question
    Top Eiki Office Equipment & Supplies Experts
    jasbo
    jasbo
    neOen
    Level 1 Expert
    Jaime Hernandez
    Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
