Question about Apple Power Mac G4 Dual Mac Desktop
Hard drive disappeared from my desktop - Apple Power Mac G4 Dual Mac Desktop
  • kmk5 Jul 31, 2010
    one of my hard drives disappeared from my desktop on my powermac G4. I restarted the computer and it appeared momentarily and then disappeared again. I checked the system profile and it does not display the name or size of the drive. What is causing this and what can I do?
  • 360 Answers
Hi, is it a C drive or external hard drive?
Take care
Posted on Jul 31, 2010
  • Apple Master
  • 13,433 Answers
This should help.
Launch ScriptEditor and copy and paste this into the script window:
tell application "System Events"
set visible of disk "NameofDisk" to true
end tell
tell application "Finder" to quit
delay 1
tell application "Finder" to launch
Replace NameofDisk with the actual name of your disk, hit the Compile icon to make sure the script didn't acquire any errors, and then hit run. This should set the visible attribute back to visible and quit and relaunch the Finder, thus making the change available.
The same thing can happen to other drives, both internal and external. You can use the same Applescript to fix those as well, just put in the name of the drive.
for more instructions click here http://www.pinkmutant.com/articles/invisible.html
How does this unit work. Iomega desktop hard drive 1TB , USB 2.0 Should there be a menu with prompts or is it a question of selectively copying and pasting directories to save .
Copy and paste, its basically adding another physical drive to the system. If you unplug it you will see the drive letter it is disappear from the my computer window when you have it open.
May 27, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I am having the exact same problem listed above. I will copy it in case you can't read it for some reason: Drive is mounted on the desktop (Mac OS 10.4). There are no problems with it according to Disk...
for one the drive will not be mounted to the desk top , since it has no operating system installed on it , it will fall redundant to the C drive
in my computer , disappearing is the hard drive booting to the C drive
are you able to use this drive ? if you are I suggest emptying it and
reformatting the drive then fill it back again if the drive doesn't work
check all power cords , cables ect. give me more details to better help you wit this problem David terminalcon
Jan 11, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My windows disappeared, had to reinstall, it worked but its still not right... could something else be wrong and what
start with your hard drive since you suddenly lost your OS. use a different hard drive to test if the problem is failing harddrive.
Oct 17, 2009 | E-Machines eMachines Desktop PC
Smartdisk 80gb has power connection, but data (Mac)
scan the your computer and smartdisk for viruses
the problem you are mentioning about the desktop icons could be due to viruses
also run chkdsk utility on the smart drive after virus scan
Jul 12, 2009 | FireLite (USBFLB80) Hard Drive
External hard drive stopped working
Hmm any sort of nise from the disk is not a good sign. try using the unit on another Pc. if you have the same issue you might have to take it for warranty.(if you have warranty)
May 22, 2009 | Maxtor OneTouch II external hard drive...
Can't open external hard drive.
Hi, not sure about this one, you could try looking at the external hard drive, it should have small connoctors at rear, near power cables, the conectors should be configured for a "slave", if its wrong, computer is trying to look for opperating system, and cant, pannicks, & sulks.
The external drive should now come up, d: or e: or f: or h: or whatever!
Hope this helps.
Dec 31, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
Hard disk icon disappeared from desktop
To add the hard disk icon back onto your desktop, first click the "Finder" button in the dock. It is the dark and light smily face icon at the end of the dock.
Next, click the "Finder" menu item at the top of the screen and then "Preferences". In the "Finder Preferences" window that opens, click the "General" button. From there you can select what system items appear on your desktop. You can click "Hard disks" to re-add the hard disk icon.
Oct 21, 2008 | Apple iMac 24" Desktop
Windows XP SP2, Intel DG965WH mobo. Two SATA hard drives, two EIDE hard drives (WD200EB). Suddenly one day, without warning, the two EIDE drives just disappeared from the Hard Disk Drive list and files...
the problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Aug 01, 2008 | Computers & Internet
Apple Power Mac G4 Dual Mac Desktop Logo
100 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
