Question about Canon EOS Rebel XSi Digital Camera
Canon XSi will not turn on
My Canon XSi will not turn on. The batteries are fully charged and it was not dropped. It is only 7 months old.
  • 94 Answers
I think flash pcb or main pcb gone dead so its require to change. Take it to canon service centre.
Posted on Aug 04, 2010
Wb button blinks blue then turns camera off
Make sure battery is fully charged. Remove any SD card - does it still do this? If not, it may be defective card, or it may be a bad SD circuit board. Try another card. If it deos the same with another card, replace SD circuit and re-test.
This assumes camera has not been impacted, dropped, water damaged, etc.
Sep 17, 2013 | Canon EOS Rebel XSi Digital Camera
My rebel xsi won't turn on. there is nothing. I used it yesterday and it was fine. I changed the battery and still nothing! HELP!
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 09, 2012 | Canon EOS Rebel XSi Digital Camera
My camera automatically turns off and won't turn back on when i use the flash. the only way i can get it to turn on again is by putting the battery back in the charger, this also happens when the...
it would appear the battery is "weak" and needs to be replaced. although testing it with a battery tester may show it is fine. when you turn on the camera you are putting the battery under a load and the voltage may drop too low. quick test would be to test the battery voltage after you take it out of the charger and then again after you have used it to power on the camera. ebay would likely be your most inexpensive source for a replacement battery.
as a side note i suggest you go to the canon website to find out if there is a recall on that particular battery. i realize this is about camera's but my garmin gps battery was recalled (and the gps was about 4 years old) and it was replaced for free.
May 09, 2011 | Canon EOS Rebel XSi Digital Camera
Camera Canon Rebel XSI not recognise flash 430Ex. The shoe looks OK and contacts on Flash the same
Clean the Hot Shoe and make sure there is no sulfur layer or dirt. MOst of the time its happens for Sulfur layer and not proper connection with flash shoe and camera shoe. Make sure all this and let me know. Also make sure the battery of the flash are fully charged and thats turn on mode.
Jan 06, 2011 | Canon Speedlite 430EX TTL Flash
My Canon Rebel Xsi is constantly saying Busy. I cant take pics. My battery is fully charged, my card is empty. I have purchaced a ultra fast memory card. What can I do? Please help me....Thanks
i JUST had this problem with my EF70-200mm f/2.8 L IS II USM..
i was shocked at the time...but i did this to get it working again
1) turn off and on = doesn't work
2) turned off everything, removed ext. flash, battery compartment, batteries, unmount lens...reseend everything back in, turned on and it went away
Jun 13, 2010 | Canon Digital Rebel XSi Digital Camera
Can't switch on the camera
I think the charger of the camera might be your problem maybe you'll have to buy a new charger goodluck:) and please rate this solution...
Jun 06, 2010 | Canon EOS 450D / Digital Rebel XSi Body...
My Canon Rebel XSi screen will not turn on even though the battery is fully charged.
Does it take pictures? If it does, the display may be off, try pressing the DISP button a few times. If not, the camera may need to be reset, the battery may be faulty, or the camera may need to be serviced.
Feb 26, 2010 | Canon EOS Rebel XSi Digital Camera
How to replace cr2016 from 450d/XSi or 500D/Xt1
The other bloke doesn't know what he is talking about..this is plainly obvious.
Looks like the CR2016 is inside the battery compartment under a small cut-out plastic piece (on same side as hinge). Use a torch and you can see it under this plastic piece.
You either need to dissemble it to get access or break off this plastic cover to replace...or take it to canon.
Dec 22, 2009 | Canon EOS 450D / Digital Rebel XSi Body...
Err 01 on Rebel XSi
shutter struck, if the battery has no enough charge the shutter motor will not rotate fully,charge the battery and try.
Aug 31, 2017 | Canon Digital Rebel XSi Digital Camera
Busy light comes on when I start the camera
I believe your camera comes with a 90 day manufacturer's warranty. I would goto Canon's website as soon as possible.
I Can Fix It
Mar 13, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
382 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
