Question about Vacuums
My Bisell Revolutionary Lift off vaccuum has a high consistent noise. I have changed and cleaned all filters, but the problem still exists. The vaccuum is approximately 1 - 1 1/2 years old.
    President:
  • 1,673 Answers
Did you check the hose and the dirt inlet by the brush roll for a partial blockage? If no blockage, then it may be coming from the main motor, replacing it is the only way to fix it if it is coming from the motor. Also, some people can hear these higher frequencies, and most can't, so if this is what it is, there may be no fix for it other then a different vacuum.
Posted on Apr 24, 2008
Bisell 9500 replaced hepa filter vacuum not turning on
Some (not all) of them have a wire or switch that the filter must press back between the filter and the back of the vacuum. It prevents the vacuum from running unless the filter is installed correctly (they never tell customers about this)
Apr 08, 2017 | Bissell Vacuums
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
Don't picK up the dirt and has a noise
Have you changed the filter? What kind of noise? Unusual high pitched noise? There could be debris stuck in the hose or the secondary filter/screen could be clogged. What were you vaccuuming when this happened?
Mar 13, 2011 | Bissell Vacuums
My son spilled mica all over my carpet. To clean it I used my bissel vaccuum. Now I have orange mica in the removable filter area as well as up inside the part that spins. I need to clean it out, but don't...
Load it into the trunk of your car, take it to a gas station and use the tire inflater hose to blow all the **** out of it. May have to get a tire stem in order to use it as a blower.
Aug 28, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell LOUD noise!
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on proper cleaning and maintenance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 01, 2010 | Bissell Vacuums
My vaccuum seems to clean, but makes a louder noise than normal
I would check and clean any of the filters also check the pipes for any blockages etc.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Dyson Vacuums
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
