Roland SP540V problem: PINCH ROLLER ERROR SHEET SET ERROR
I have a problem sheet set error set again. what can i do now
Posted on Feb 26, 2011
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
My Dell 942 printer will not pull the paper into the printer, unless the sheet is pushed in very far. The roller spins but does not grab the paper. Any thoughts? For one sheet I can print with the added...
If you use coated or matte paper at all, it will slowly put a coating on the pinch rollers, causing the problem you describe.
Get some isopropyl alcohol and lint free rags and clean the rollers thoroughly. That should solve the problem.
Oct 11, 2009 | Office Equipment & Supplies
R360 wont feed paper in to printer
You need to clean the pinch roller at the back of the printer using a cleaning sheet. These come with packs of Epson Photo Paper and are slightly tacky which removes the paper dust and grime from the pinch roller.
Mar 12, 2009 | Epson Office Equipment & Supplies
Hp laserjet 1320
You might try this before turning it over to the tender mercies of a tech:
Use a high-quality bond paper and remove any other sheets from the feed slot or tray; 'paint' a stripe of alcohol across the page; preferably pure, rubbing alcohol if you can't get other. Let the machine start to pull the sheet through but hold it so it can only take an inch or so before stopping; hold and release several times and hope that one of the stops is between pinch rollers that will yield up its load of paper fibers.
This is NOT a 'sure-fire' method but can often cure the problem for a while before the rollers load up with paper fiber again. BTW, 'bargain' paper can cause this to happen earlier than quality bond since it has more loose wood fiber that can depart from the sheet and build up on rollers.
Sep 23, 2008 | HP LaserJet 1320 Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Apr 13, 2008 | Sony Betacam SP Small Videocassette 30...
Sony DCRTRV 25 : Getting 31:23 error message
possible pinch roller problem.The pinch roller rubs against the capstan motor to pull out of the cassette .This pinch roller seems to fall completely or loose causing the error.The other possiblity is that the capstan motor is not turning ..might need repair..
Nov 29, 2007 | Sony Handycam DCR-TRV25 Mini DV Digital...
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
1,499 people viewed this question
jasbo
jasbo
