Question about Nintendo Wii Console
Para entrar en internet - Nintendo Wii Console
  • 864 Answers
I can help you with this. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Como hago para grabar
Hello
Antes de usar su nueva grabadora de DVD, usted tendr? que ajustar el reloj y, si se ha conectado un
se?al de televisi?n, explorar el espectro de la se?al para desactivar debilidad de los canales
Para ajustar el reloj:
1. Encienda la grabadora.
2. Pulse SETUP para entrar en el men? de configuraci?n.
3. Utilice y para seleccionar el reloj sub-men?
y pulse ENTER
4. Utilice y para seleccionar la fecha y pulse
ENTRAR.
5. Introduzca la fecha actual con el teclado.
Alternativamente, puede seleccionar cada d?gito
individualmente pulsando y, a continuaci?n,
modifica con el bot?n y.
6. Pulse ENTER para fijar la fecha
7. Utilice y para seleccionar Hora y pulse ENTER.
8. Introduzca la hora actual usando el teclado.
Alternativamente, puede seleccionar cada d?gito individualmente presionando y, a continuaci?n, ajuste por
pulsando y.
9. Pulse ENTER para ajustar la hora
May 23, 2011 | Protron PD-DVR100 DVD Recorder
No puedo entrar en mi facebook me dice que entre por faceboornk pero tampoco puedo:(
Tal vez el teléfono no es compatible con el formato de esta pagina! Usted debe tratar de entrar en facebook desde otro teléfono para ver si funciona!
Mar 24, 2011 | Cell Phones
TENGO PLACA BASE DFI NB71-BC i845P y no se entrar en la bios para reinstalar sistem32
Primero por que quieres entrar a la bios? system32 es un proceso de windows si tienes algun problema con ?l, es por que quizas tengas conflictos con los drivers lo cual se soluciona entrando en modo seguro y restaurando sistema hasta la fecha donde no tenias conflictos. La otra opcion que que hayas instalado hardware nuevo y te produjo el error, en tal caso retiralo y haz lo mismo.
Y si tu intenci?n es otra, al iniciar el pc aparece la tecla que debes presionar para poder acceder a la bios, por lo general es suprimir,f2.
Sep 23, 2010 | DFI NB71-BC Motherboard
La direccion de la consola esta deshabilitado mac xbox360
Conectar xbox 360 a internet; si tienes xbox 360 y quieres jugar en internet, ve este tutorial.
Como conectarse al Live.
Bueno tienes tu nueva 360 smile.gif y ahora quieres entrar a la experiencia Xbox Live y no sabes cómo. Acá una guía que te enseñara como hacer desde las conexiones de redes (VTR por ahora) hasta la creación de tu cuenta Xbox Live/gamertag.
Las Conexiones:
Hay 4 opciones para conectar tu consola:
A: Directamente desde el MODEM de VTR.
Conecta el cable de red que sale del MODEM a la 360.
MODEM ------------ 360
1. Llama a VTR (600 600 9000 opcion 3, 3), pideles que te cambien el numero de MAC al que tiene la 360.
2. Para saber como obtener tu numero de MAC debes buscarlo en las opciones del menu de 360
3. Una vez hecho esto estás listo para entrar a Xbox Live.
B: Desde el MODEM de VTR 2 conexiones (USB y RED).
MODEM red ------------- 360
usb ------------- PC
1. Conecta el otro dispositivo que tengas (Ej. PC) y conectalo via USB.
2. Conecta la 360 por el Cable de Red.
3. Llama a VTR (600 600 9000 opcion 3,3), pide que te registren 2 MACs, la del PC y la 360. Así ambos quedarán con Internet.
4. Una vez hecho esto estás listo para entrar a Xbox Live.
C: Router
Modem ------- Router ------ 360
1. Conecta la 360 al router con un cable de red.
2. Ahora hay que configurar el Router. (Ruteo de puertos)
1. Tienes que entrar al menú de administración del router. Generalmente la dirección es 192.168.0.1, después te pedirá nombre y contraseña. Generalmente es User: admin, sin password. Si no funciona, vas a tener que conseguirtelos.
2. Una vez dentro del menú.
3. En la página eliges Forwarding.
4. Elige la marca de tu router.
5. Elige Xbox Live 360
6. Sigue las instrucciones de cómo “rutear” los puertos para la 360 (88 y 3074)
7. Una vez ruteados los puertos, estás listo. Empieza la creación de tu Gamertag.
D: Router via Wifi
Router )))))))) 360
1. Necesitas el Adaptador Wifi para la 360
2. Necesitas un router con soporte Wifi b/g
3. Prendes la 360 vas a la parte de Sistema – Config de Red – Windows Connect Now.
4. Eliges el Spot Wifi
5. Desde un PC, Ahora hay que configurar el Router (Ruteo de puertos).
5. Elige Xbox Live 360, Sigue las instrucciones
6. Una vez hecho lo anterior, estas listo para crear tu Gamertag.
XBOX LIVE
Entendiendo Xbox Live:
Primero hay 2 tipos de cuentas para Xbox Live. Gold y Silver.
SILVER
• Permite a otros jugadores saber quién eres y cómo juegas gracias al perfil de jugador único.
• Entra en el Bazar Xbox Live para conseguir fantásticas descargas (incluidos los juegos clásicos de consola de Xbox Live Arcade), demostraciones y tráilers de los juegos que van a salir próximamente.
• Prueba la acción multijugador con acceso a partidas multijugador masivas. Lo único que tienes que hacer es crearte un gamertag.
• Disfruta de la acción multijugador sin límites con las oportunidades suscripción de prueba al nivel Gold.
• Crea y mantén una lista de amigos para conectarte y comunicarte instantáneamente con familiares y amigos mediante mensajes de texto y voz.
En otras Palabras... Puedes Bajar Trailers, demos, etc. Pero NO puedes jugar Online
May 20, 2010 | Microsoft Video Game Consoles & Games
Como puedo entrar al Farmville, no carga la aplicación
¿Puedes por favor ponga su pregunta en Inglés para que nosotros aquí en Fixya puede entender mejor y ofrecer un mejor servicio. Gracias por usar Fixya.
Dec 05, 2009 | Facebook Social Network
Mi internet esta disponible a cualquiera como puedo bloquearlo necesito ponerle un candado llame a soporte tecnico y me cobran por su asistencia es ridiculo si estoy usando sus productos
No porque te compres un coche los del concesionario tienen que enseñarte a conducir...
Supongo que tienes un router WIFI, y que no hay encriptación en él. Obviamente necesitaríamos saber que modelo de router tienes y que tipo de direccionamiento IP estas usando para tu red local.
A grandes rasgos, tienes que conectarte con tu router (a menudo vas a poder entrar poniendo http://192.168.1.1 en un navegador). Quizas te pida un nombre de usuario y password para conectar. Si es asi, tendras que saber cual es. De fabrica una combinaciones validas serian:
usuario: admin password: admin (o dejar el password vacio)
usuario: root password: admin (o dejar el password vacio)
usuario: root password: root
usuario: 1234 password: 1234
usuario: 12345 password: 12345
Una vez dentro del router, tendras que buscar donde se define la encryptacion del enlace WIFI, escoger un tipo de encryptacion (por ejemplo WEP), y poner una clave.
Si has conseguido llegar hasta aqui y te estabas conectando por WIFI, en este momento se te desconectará la conexion. Ahora tienes que decirle a tu PC que utilice encriptacion para conectarse.
Tambien seria aconsejable cambiar la clave del usuario de administracion (el que has usado para entrar en el router).
Suerte.
Jun 23, 2009 | Linksys (WRT54GC) Router
Nesecito un password para mi laptop DELL E1405
No entiendo que clase de password necesitas para tu laptop. Quieres decir que se te olvido tu codico para entrar al laptop? o que quieres poner un codico/password para cuando enciendas la laptop siempre te pregunta por un password?
Si se te olvido tu password para tu laptop, necesitas un CD para entrar a ella otra vez.
Si quieres crear un password, tienes que ir al "control Panel" y darle at botton "user accounts"
despues ir al nombre que usas para entrar a la laptop y darle a "create a password"
despues entrar el password que usted quiere entrar a la laptop
despues dile "ok" o "save" y salga de la laptop y apaguelo
encienda la laptop otra vez y entra la nueva password
Avisenos si todavia tienes problemas. Y responda si funciono. :)
Feb 27, 2009 | Dell Inspiron E1405 Notebook
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
