Question about Samsung 26 Cu. Ft. Side-by-Side Refrigerator, RS267LA
Samsung refregerator not cooling.what type of problems?
  • Samsung Master
  • 17,130 Answers
Fault can be anyway from your compressor to low gas in the system. So first of all you will have to see if there is any fosting in the cooling coils. If so defrost by shutting the fridge for abbout 10 hours. Thereafter put the set on and see if the compressor runs for few hours in a stretch . If cooling has come back you will have to check for the auto defrosting section for failure of the timer, the heater or any wires to the thermostat. If there is no cooling still then you will have to check for gas pressure, or weakness in pumping of the compressor, even failure of valves / O rings in the compressor. If so get help find a good technician to give an estimate after his own solution which you can compare with our findings and go on. Good day
Posted on Jul 31, 2010
REFREGERATOR NOT COOLING
You have a ice obstruction,or fan in freezer may not be moving air to fresh food part of fridge, or the defrost heater may not be working.try YouTube
Dec 22, 2017 | Refrigerators
What is the cooling problem with the fridge not cooling.
If freezer is cooling check evap fan motor, if Ok check refregerant gas
Oct 04, 2014 | Refrigerators
My samsung rs2533rs is not cooling
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 23, 2012 | Samsung Refrigerators
The refregerator is not cooling well. there is an ice build up at the condenser.
Use a hair dryer to get rid of the ice and see if it gets colder.may also be low on coolant.
May 14, 2011 | Samsung Heating & Cooling
Freezer works but not the refregerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Samsung RS2556 Side by Side Refrigerator
WATER IN BOTTOM OF REFREGERATOR
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 03, 2010 | Maytag Refrigerators
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
