Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
49.4c06 service error
The printer has a 49.4c06 service error on its display. Well not print or respond to buttons on the printer face. Turned it off and back on which got it printing one time but now the error is still there when I turn it back on.
thanks!
  • fxmiller Sep 18, 2008
    I have the same problem on a HP4200 Laser Printer
  • Anonymous Apr 01, 2009
    How bout Laserjet 4250 update?
Apparently the fix for this is a firmware update for the printer. You can find firmware updates for this model at the following link:
http://tinyurl.com/4v5q34
Choose the one for your operating system and follow the directions for installing it.
Posted on Sep 23, 2008
  • balld572 Sep 23, 2008
    ooops... that link above is for a HP 4600DN. Should be able to find your printer from there hopefully.
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
Tip
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Office Equipment & Supplies
I am having problems with printing......this is error message on the printer screen Ink system failure......0xc19a0022
Hello and Welcome to FixYa!
The error
oxc19a0022 is mostly occurred in HP printers. To solve the error code oxc19a0022,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Aug 27, 2011 | HP Photosmart 3310 Printer
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
0xc18a0206, Follow the given steps
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP B 209a All in One printer has a message that reads Ink System Failure Oxc19a0022 I have turned the printer off and on and disconnected the cords but the error message is still there. The ...
Hello and Welcome!
The error 0xc19a0022 is mostly occurred in HP printers
To solve the error code 0xc19a0022, Follow the given steps
Apr 09, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
I am facing ERROR 0xc19a0021. I do not knew what i have to do with that. How can i solve this ERROR?
Hello thanks for using Fixya
To solve the error code 0xc19a0021. There is following solution.
Follow it step by step
By this error will automatically remove. But if u face still this error then printer service required
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 21, 2011 | HP Photosmart C5180 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Will not print
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | HP C6280 All-in-One Printer
Service error 5100
Hello it only a try but could be
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
13,750 people viewed this question
Ben Johnson
