Question about Intel D945GNT Motherboard
My Mother is Intel D945GNT with Intel D Processor. Ipurchased it in 2006. From that time till 2007 it works properly. After that there is hang problem comming, and during hang also the display became hazi display and stop working. Only the way to get rid off this is restart the system. But now a day it is coming frequently. I am not able to solve it. Please help or tell me the place in chennai where it can be repaire. For you information: 1. Change the RAM(instead of 2X256 MB i put 1GB RAM) 2. Changed OS so many time with different OS Like XP, Win 2000, Vista, Ubuntu, GOS Etc) 3. Changed Processor Fan with new white glue between processor and fan base. 4. restored all mother board connection so many times. 5. Updted the D945GNt Bois software from intel site. 6. Removed all extra cards like TV tuner Card Plus Extra LAN Card. After completion of all task mentioned above, problem is still there. And problem comes randomly. Kindly provide me any solution. Thanks & Regards Santosh Gupta
  • Intel Master
  • 11,800 Answers
The onboard video chip is dying. Since it's a part of the chipset, it might be also dying. If you're lucky all you need to do is to add a separate video card, disable the onboard video and your problem will go away.
Posted on Jul 31, 2010
Dark speck on processor
It may be the temperature problem. If the heatsink and the fan does not sit tight on processor the heat from the processor will not be dissipated properly and the heat rises up and the processor shuts off as soon as it starts working. So please see that the heat sink and the fan on the mother board sits tight. Also apply heatsink paste on the surface of the processor which comes in to contact with the heatsink. It comes filled in Syringe and retails around Rs.10-20 only. I think it will solve your shotdown problem.
May 10, 2013 | Intel Computers & Internet
What are maching ram for Intel D945GNT
Hello here is the homepage:
http://www.intel.com/support/motherboards/desktop/d945gnt/sb/CS-026631.htm
The board has four DIMM sockets and support the following memory features:
  • 1.8 V (only) DDR2 RAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 4 GB maximum total system memory.
Windows xp does not support, more than 3 gb ram in the 32bit version.
Please take antistatic precautions, when working on the mainboard.
The drivers site is here if needed:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GNT
Good luck
Jan 24, 2013 | Intel D945GNT Motherboard
I have an Intel 945GNT Motherboard along with a Pentium D processor running at 3.4GHz and 3 sticks of 1GB RAM at 533MHz. I have given it to one of my engineers for repairs and he said that the motherboard...
The D945GNT appears to have been discontinued - however, processors are always made to fit a certain standard socket type. In this case, you will be looking for a motherboard that uses socket LGA775 and has a FSB (Front-Side Bus) speed of 533 Mhz in order to use the same processor and RAM.
These motherboards are still available through the internet, although they are getting older and may be harder to find, but any one of them would work properly. My recommendation would be to read as many reviews as possible before deciding on a certain one.
Motherboards that support 533MHz RAM seem to be harder to find these days, but boards with 800 MHz FSB speeds are pretty common, so you might have to buy new RAM sticks to go along with the new motherboard. The good thing is, RAM isn't all that expensive these days. I would advise checking well-known internet retailers to see if you can find a board that suits you.
Hope this is helpful!
May 10, 2011 | Intel D945GNT Motherboard
Hello, I have a Intel esys 865 gv / 775 motherboard. and win xp installed. The system hangs up after about 5 minutes after booting up. No error messages are displayed. all cooling fans are working. and...
Your system is probably hanging because of high temperature. Check cpu temperature in bios hardware monitor. If it is to high check the heatsink is fitted properly also apply thermal paste between processor and heatsink.
Mar 08, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My D945GNT motherboard is not working
Dear Sir,
Please Remove Once Processor and install it again. If not ON please goto motherboard service station change once BG. It will work.
Okey
Cheers
Jaggu
Sep 23, 2009 | Intel D945GNT Motherboard
REBOOT PROBLEM BY CHANGING OF PROCESSOR
Try to remove the battery so it reset the bios and then power it up.
Jan 26, 2009 | Intel Desktop Board D815EEA2 Universal...
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Intel D945GNT Motherboard Logo
148 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
