Heating & Cooling Logo
Posted on Apr 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delonghi AC problem
This portable AC unit is in our server room. It keeps shutting itself off and we can only get it back on by hitting reset. What is wrong with it???
Anonymous
Level 2:
Scholar:
  • Expert 149 Answers
  • Posted on Apr 24, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
149
Questions
0
Helped
69146
Points
258
Suspect a faulty running capacitor.
2helpful
2answers
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Unit keeps turning on and off from cooling mode to LT mode every 10 minutes. Please help.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Also What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
Air Conditioning Boca Raton - Duct Cleaning
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
1helpful
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
2answers
I have the same problem. My Delonghi AC (PAC W160A) shows no water symbol even the tank is full. I checked for the red button , but i couldn't locate any.
Please check float valve and sensor. Some times by mistakes the error could display. Reset it by removing power or batteries and then reset it.
No power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
2helpful
Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Need AC for Server Room
I find it amazing that in this day and age IT manager will still scrimp on there server room environmental systems! It must not be that critical! Anyways you'll be better off with a split type unit correctly sized for your server room. Toshiba now have small units that can pump up to 50 meters away if needed. the key is to have it correctly sized!
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
