Question about Dell Latitude D610 Notebook
My Dell D610 laptop will not turn on if the A/C power unit is not connected to the laptop even when I've charged the battery for several hours. I recently changed the battery pack, thinking that was the issue but I'm still having the same problem. Any idea of what the problem is?
  • balfam_renta Jul 31, 2010
    Any additional insights?
  • Dell Master
  • 4,924 Answers
This means that a contact at the battery level is not right and the only way that it receives the power is from the cable ...so ..what you will have to do is to check the contacts of the battery ...The damage may be on view...on the battery location or inside on the level of the motherboard....
Posted on Jul 31, 2010
  • 5 more comments
    Thx. I'll take it in to the repair shop sometime nxt week.
  • Catalin Turcu
    Catalin Turcu Jul 31, 2010
    You can even take a look by yourself on the battery location and see if that blades are on the right spot and make contact ...if there is nothing obvious then it means that it may be inside ..but it may as well be something simple like a bent connection blade...
    I just did. By the "blades", I suppose u mean the grooved area that battery uses to fit into the laptop. They appear to fit in properly. But it still will not turn on without A/C cord.
    If it's a bent connection blade, will that be on the inside or outside of the battery? What are the chances that a new battery will also have a bent connection blade?
  • Catalin Turcu
    yeah ,,that's what I meant ..the connection area..to be not oxidized or something like that ..but it appears t be in order it may be a connection inside that is broken ...cause if the laptop function perfect with the ac cord the only thing that may be wrong is the connectivity with the battery ..
  • Catalin Turcu
    By the way ..I see that you are reffering at the battery ..I actually mean the laptop side .....cause if you got a new battery there is no chance that it has the same issue ...So the issue is inside the laptop ...or on the laptop's connection points ..
    Thx.
    Genius:
  • 1,040 Answers
There is a hardware problem. the problem may be is with the connector of the battery. the connection between battery and motherboard has lost. Therefore get it serviced...
Thanks....
How long for battery recharging D610 ?
when the computer is turned off, the AC adapter charges a completely discharged battery to 80 percent in about 1 hour and to 100 percent in approximately 2 hours. Charge time is longer with the computer turned on. You can leave the battery in the computer for as long as you like. The battery's internal circuitry prevents the battery from overcharging. So About 2 to 3 hrs
When you connect the computer to an electrical outlet or install a battery while the computer is connected to an electrical outlet, the computer checks the battery charge and temperature. If necessary, the AC adapter then charges the battery and maintains the battery charge.
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.
Jun 06, 2014 | Dell Latitude D610 Notebook
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
When I try to turn on my Dell D610 Laptop it immediately shuts off.
Hi
Try to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
May 14, 2011 | Dell Latitude D610 Laptop Computer -...
Why wont my dell D610 charge i have changed the battery and charger
Hey!
If you are still encountering the problem charging your laptop's battery, it is possible that the port where you connect the adapter or the port for the battery is damaged. It will still receive power but it won't charge.
Best solution is to replace the motherboard. Just make sure you would get the exact same devices on a replacement board.
Hope this helps! :D
Sep 09, 2010 | Dell Latitude D610 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Apr 01, 2009 | Dell (F2273) Motherboard
Dell D610 Batteries don't charge when AC adater is plugged
this is usually a sign of a common problem with these laptops. Usually the power works but it will not power the batteries to charge them. If the power adapter is fine- you have a bad motherboard.
Nov 23, 2007 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook Logo
Alun Cox
