Question about Breville BCG450XL Manual Burr Grinder
So how do I 'crack it open' to tighten the grind? - as per question by Ron. Regards, Michael
My lexus AD 1994 is overheating. What should I do?
Hello Malena,
Here are some tips to try, to narrow the search for the fault.
1. check coolant niveau, refill to the mark, see if there are leaks anywhere from your car.
2. take out the thermostat (usually located inside a "house" where the rubber hoses from the radiator, meets the block), and put it in boiling water to see if it works(should open at a given temp). or replace with a new one.
3. Do you hear a whining or grinding noise from the waterpump? If so, the waterpump should be replaced.
4. It can also be trapped air in the system, squeese the rubber hoses, and refill coolant.
If there are none of the above, there might be a more serious problem, like head gasket or cracked head.
I hope this helped, and good luck, hope everything works out fine for you.
Best regards
Per
Jul 11, 2011 | Lexus GS Cars & Trucks
NOISY FLEX PLATE, KEEPS CRACKING AROUND MOUNT ING SCREWS (3) , WELDED UP CRACKS AND REPLACE SCREWS, IN A WEEK STARTS GETTING NOISY AGAIN WE HAVE WELDED THESES CRACKS 3 TIME NOW, HAVE REPLACED NEW FLEX...
sounds like it is incorrect flex plate
for bolts to keep coming loose i wouldsay the bolt threads in end of crank have been streched thru over tightening
you may be able to redrill and tap these
to do this you will have to pull engine
you alsocannot weld craCKS IN A FLEX PLATE
FLEX PLATES flex THEREFORE WELDING IS A WASTE OF TIME
WELDING WILL ALSO PUT FLEX PLATE OUT OF BALANCE WHICH AGIAN WILL CAUSE CRACKS AND PROBABLY WAS THE ORIGINAL PROBLEM TO START WITH
Dec 14, 2010 | 1991 Eagle Summit
I have a HP Compaq dc7600 Convertible Minitower with a pentium 4 ht 3.2ghz I go it with no ram and I dont know what type it takes can you help me? Thank ron
DDR 2 ram is to be installed ask the retailer to give you DDR 2 ram you can install
512MB DDR 2 ram for learner/beginner 1GB or more for medium use More than 1GB for professional use
Dec 04, 2010 | HP Compaq dc7600 Convertible Minitower PC...
1st ger is grinding
shop time would be around 3 hours @ roughly $58.00 per hour depending on where you live. Split cases remove and replace gear (if that is cause) plus shop materials would cost you in the $ 245.00 plus or minus range. If you have a good mechanic/honest it can be done for less or more depending on if it is indeed just the gear. Remember ! this is for current charges in my area. I have heard of shop rates pushing $70.00 per hr
Mar 07, 2010 | 2003 kawasaki KX 250
The drivers side window will not go up evem. It jams itself half way up.
there may be something stuck in the door panel or check for a child safety setting.
Nov 30, 2009 | 2007 Jeep Liberty Sport
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
What kind of trany oil for 2007 cts
Hello there:
this is what the manufacture suggests
TRANSMISSION FLUID TYPE 2007 Cadillac CTS 3.6L
The Transmission Fluid Type 12154
Application:
With automatic transmission
5L40-E transmission Castrol dexron VI ATF
Hope that this is very helpful for you
best regards michael.
Oct 29, 2009 | 2007 Cadillac CTS 3.6L
My zanussi f1045w is grinding when spinning what could the problem be
Hi there.....the problem could be ...(a) something traped between the inner and outer drum....usually a bra wire....(b) Debri in the drain pump can result in grinding noise...(c) CRACKED inner drum spider unit..and or failed main bearings..test for this by opening the door with appliance switched off place your hand at outter edge of inner drum and test for lift in drum..there should'nt be any lift at all
regards Sir Galahad
Aug 12, 2009 | Zanussi F1045W Front Load Washer
CRIME STOPPER REMOTE CAR STARTER POPS TRUNK
Michael, Per your description, it sounds like the deck lid button on your remote may be stuck. Remove the cover and reassemble, make sure the button is free to move in and out.
Let me know.
Regards,
Feb 26, 2009 | 1999 Chevrolet C1500
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
Breville BCG450XL Manual Burr Grinder Logo
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
