Question about Proform Exercise & Fitness
I have a noisy Pro-Form Model 285T treadmill
I have a Pro-Form Model 285T treadmill. Seems to be getting noisy when it is running. I'd appreciate knowing exactly what places I should lubricate and what lubricant to use.
Also, do you think the fact that it is getting nosiy means that I have to tighten the walking belt?
Thank you,
Rocco46 (Richard)
    President:
  • Proform Master
  • 832 Answers
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
Treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Sep 19, 2012 | Proform Pro - Form Treadmill 705 CST
Problem with pro.form treadmill Model No. 831.299212 Serial No. M30377474
The problem is that the belt is old and is overheating your motor. That model is way too old to put that kind of money into. Buy a new machine.
Oct 20, 2017 | Exercise & Fitness
Pro form 400gi belt adjustment
should be a allen wrench adj on the rear of the tradmill
Nov 11, 2011 | Exercise & Fitness
I have a Pro-form 595PI treadmill..bought it used and has been working great until now.It seems that when I get on it , it seems to be slipping and not a fluid motion to walk or run on...Whats up???
check tension on the w/belt to loose will make it slip other wize check your drive motor belt thats under the hood. if you see a bunch of black dust your belt is worn replace
Mar 17, 2011 | Proform 595 PI Treadmill Walking Belt
My pro form 730 runs then its stops after about 30 mins
If you have not lubricated the deck I suggest you doing so you may purchase the lube @ Gymparts.com Part # TM001
May 13, 2010 | Proform 730 Folding Treadmill Model...
Pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Sep 11, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
1,015 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
