Question about Apple iPod touch
I tried restoring my ipod touch 2nd generation, and it's not working! Please help?
    Brigadier General:
  • 3,917 Answers
Hi
This sounds likely it’s a USB power issue .Make sure you have a full power USB connection (many laptops and keyboard connectors only give 100mA max rather than the full 500mA, also do not connect via an unpowered hub either as this only PARTLY charges the ipod. Next connect it direct to the computer on a full power USB port or via a powered hub (mains transformer connected to it) and it should be OK.
Leave it charging on this for at least an hour before proceeding further. Make sure you have the latest itunes 8.0.2 (downloaded on your PC from
www.apple.com/itunes/download then restart PC first) and reset the ipod before connection (menu and centre key till screen blanks then connect once it lights up).
Then say YES to the 'pair with this computer' Message if after doing the USB power check you still have problems you need to call apple for a swap for replacement... as batteries can be killed by improper usage apple has a page at
http://support.apple.com/kb/HT1726 that tells you how to get the most from your battery or the update could be iffy take it to either a friend with a Mac if you use a PC or a friend with a PC if you have a Mac - this can fix it if not try taking it to your local apple store or the shop you bought it from.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 31, 2010
Unfreezing ipod otuch 2nd generation
Hi linda_wat834
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu. Then connect the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Please take time to rate me
Bud
Apr 03, 2013 | Apple iPod touch Second Gen (8 GB,...
Crack ipod touch password
Have you tried plugging to your Computer?
Jul 25, 2012 | Apple Ipod Touch 32 Gb 2nd Generation...
The slide bar will not slide to unlock on my ipod touch 2nd generation. I've tried restarting. It holds a charge and I can play it on my docking station. I can't use it by itself.
I had the same problem with my iPod touch 3rd Generation, the slide bar will not slide to unlock. I could however use the slide to power off at the top of the screen. I tried everything from rebooting it to a full restore and nothing worked. I finally took the Touch Screen Glass Digitizer off and the ribbon cable that connects to the board had come loose. I pluged it back in and everything worked again.
Aug 01, 2011 | Apple iPod touch Second Gen (8 GB,...
Replace ipod touch 2nd generation glass
Please check the links:
http://www.rapidrepair.com/guides/ipodtouch2g/ipodtouch2grepairguide.html
http://video.google.com/videosearch?hl=tl&q=How+to+replace+the+screen+of+iPod+2nd+gen&oq=&um=1&ie=UTF-8&ei=K7x1S4jJKsLX8Ab4mfzzCQ&sa=X&oi=video_result_group&ct=title&resnum=4&ved=0CCQQqwQwAw#
Good luck and have a great day!
Feb 12, 2010 | Apple iPod touch
I have a 2nd generation ipod touch and recently my music cover art is not the same as in my itunes. any suggestions?
there could be conflict with another image in your library that has the same name...if nothing else works, try restoring your device..
Aug 22, 2009 | Apple iPod touch
Ipod wont restore
hi cop out answer: http://support.apple.com/kb/TS1456
Jul 14, 2009 | Apple iPod touch
Can't unlock my iPod Touch!!!!
u r screwed up. get help from mac people.they have utility to bust it
Jul 13, 2009 | Apple iPod touch
Ipod turns off when i listen to music.
Sorry but you got another bad Iphone that your going to need to return if your restored this. There is not much remedy here but apple's **** needs replacment again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Apple iPod touch
Stuck
Try to plug it into the computer and press restore through itunes or press and hold the home(square) and the top button.
May 13, 2009 | Apple iPod touch
Can't upload songs on my ipod
i have the same problem. i tried everything but nothing worked .. sorry
Jul 28, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod touch Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
