Question about Fisher and Paykel Fisher & Paykel Washer
My Fisher & Paykel exellence 9 is not pumping the rinse cycle water out then just stops & beeps. Do the lights that flash up mean anything? The ones that are lit up from left to right are 3, 4, 5, 6 & 7
    President:
  • 1,554 Answers
It does mean a thing and it is fault code 62 which means a pump over-current fault. The pump motor is drawing excessive current most likely due to a short circuit. Do not run the machine until the pump is replaced; otherwise you will damage the Motor Controller Module and will cost you further repairs. You can purchase a replacement for the pump here. Select the model of your washer then the drain pump.
Unplug the machine, drain the water from the tub then lay the washer on its back on protective material. Ensure that the washer is slightly raised at the top to prevent residual water in the tub from spilling out. Remove the base panel by easing the tabs, located at each corner, with long nosed pliers, then pry the panel off using a flat bladed screwdriver.
Disconnect the pump connections. Turn it towards the front of washer until the pump retaining clip prevents further turning, then release the pump retaining clip by pulling it away from the pump.
Turn it further until the pump disengages. Make sure catch residual water in the pump sump that will spill out when the pump is removed. Install the new pump in reverse order of the removal steps.
Posted on Jul 31, 2010
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Aug 30, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
55 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
