Question about Dell XPS M1330 Notebook
Dell xps m1330 has erratic usb ports. Sometimes they cease to work and then start again. After reboot most of the times they connect well with devices, but even then it's uncertain. Dell has changed the motherboard but still they malfunction. Only thing that works always is the cordless mouse. Thanks
  • Dell Master
  • 17,130 Answers
It is also possible that the USB adaptors need to be checked if there is a contact issue. what you can try is to use an USB extentor and connect the device. If this works then the ports are fine and you need to check if the usb connection tracks are worn out. Always try to insert the device in the same position and not sideways. If not then reinstall your drivers , check if there is any virus/malware in the system, if so use backup/restore and try. Since after rebooting the device works then it can be if the OS software need reinstallation. So check this out. Good day
Posted on Jul 31, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 98 Answers
You need to update the BIOS of the computer. Log on to support.dell.com and look for the BIOS updates for your computer.
Once downloaded and saved on the computer run the update and leave the computer to complete the updated. It might restart a couple of times.
This should fix your issue.
How to reset dell xps m1330
You may follow the steps mentioned below to restore the Dell XPS M1330 to its factory default:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
9 You will need to run Windows Update as well as Live Update for your virus protection as these will be seriously out of date.
Hope this helps..
May 17, 2014 | Dell XPS M1330 Notebook
Connect second screen
usually thru the USB port
Jun 28, 2012 | Dell XPS M1330 Notebook
Dell XPS M1330 Backlight Problems
Really does sound like a backlight problem. They usually don't cost much and are easy to replace if you are good with a screwdriver.
Apr 25, 2010 | Dell XPS M1330 Notebook
Dell xps m1330 laptop
  • First purchase/get a usb mouse and plug it in. It may take a few minutes for it to start working. It will have to install the driver first.
  • This will allow you to get around in windows.
  • Now open your device manager
Windows xp – Start button>run> type devmgmt.msc
Vista/Windows 7 – start button> in the search box type devmgmt.msc
  • Look for a ! ony any device and right click, select update driver
  • If you do not see a ! on any device, your touchpad may simply be bad and need replaced.
  • In ebay search for; manufacturer, model, touchpad
replacement of the touchpad is a whole different set of instructions.
Jan 24, 2010 | Dell Computers & Internet
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Jun 01, 2009 | Dell XPS M1330 Laptop
Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
May 06, 2009 | Dell XPS M1330 Notebook
Dell xps m 1330 starts fine but goes ...
Boot into Safe Mode and change the video resolution to the lowest resolution supported. Reboot the machine normally. The problem should have disappeared. From here you can readjust your display resolution to any higher resolution supported by the system if you wish.
Apr 01, 2009 | Dell XPS M1330 Notebook
I want to reboot my laptop to the windows XP, im using Dell XPS M1330 with Vista home premium
Reboot? You mean restart? Click Start, click the arrow beside the Lock button and choose Restart. It's the same.
If you mean System Recovery (wiping out everything but the OS and making the PC new), then there must be a software like Recovery Manager. Search Start Menu.
As it is a Dell, you must have a recovery partition on the drive. It will be just as new.
Or use the set of CDs that you created when it was new, or one which you got with the PC. If you didn't get and you didn't even make it, ask Dell to send a set for your model.
If nothing works, then use a Vista installation disk that you can buy in a retail store. Note that you won't get the pre-installed software that you got from Dell when you removed the PC from the box.
Nov 28, 2008 | Dell XPS M1330 Notebook
Dell XPS M1330 Notebook Logo
292 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
