Question about Audiovox CE-520 CD Shelf System
Is there a way to use the aux on the audiovox ce520 with out a remote, so if i wanted to listen to a movie through the speakers i could?
I have a toshiba tv it's not a flat screen but its
If your universal remote has a video source select function, you should be able to use that as the aux(iliary) mode
Sep 07, 2013 | Televison & Video
Remote is broken, how do i switch the source?
The remote is needed to change the deeper settings, if you still have the old remote take it to a TV repair shop, he may be able to do something, or better still may have a used one. If you come up empty, you will have no choice but to order a new one.
Mar 27, 2012 | Televison & Video
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
No sound
Make sure remote AMP Wire is wired up which is used for stereo to tell amp when to turn on
PLus make sure the AUX wires for L And R sound are plugged in the input not output
Jul 31, 2010 | Audiovox Jensen Power 760 Car Audio...
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
I have looked everywhere for the users manual. I am trying to hook up the Duraband surround system to no avail. Could use some assistance
There should be the receiver box on the back are color coded wire plug-ins for the different speaks. Each speaker should be labeled on them somewhere BL, BR, FL, BL, Center, Sub each of the speakers have color coded wires that match those on the back of the receiver. plug them all up accordingly. Then your VCR or TV you would plug the component cables up to the Auxiliary IN jacks.Turn it on and set to Aux to listen to your tv or movies threw your surround sound system.
Feb 18, 2009 | Audio Players & Recorders
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
Audiovox CE-520 CD Shelf System Logo
57 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
