Question about Stoves 720EF Electric Double Oven
Can't get the light out to replace it? - Stoves 720EF Electric Double Oven
  • 250 Answers
You have to use a blunt bladed screwdriver to prize the edge of the glass cover away from the oven side. You should see a small cutout in the middle of the edge of the glass that is facing you, to put the screwdriver in. When replacing the glass cover, there is depression in the glass to allow for the bulb. Ensure you put the lense back the correct way.
Posted on Jul 31, 2010
My oven light will not shut off
the light switch which is located on either side of the oven door is faulty. this pertains to the older models of ovens. in the new models the light switch is on the touchpad. you can't repair or replace a light switch of a digital touchpad. you have to replace the entire board. thanks
Mar 03, 2016 | Ovens
My oven light is replaced with a new one but still not lighting up
Bulb socket must have a problem. The bottom contact is not touching the bulb. You may need to replace the socket if you can't bend the bottom contact back into place.
Feb 18, 2015 | Neff Ovens
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
The heating light under the lid on my holagen oven needs replaced, how do i do it.
Charliedaze
Need more information on the issue, is this light for the oven or hot plate.
when working on electrical appliances ISOLATE THE MAINS POWER BEFORE OPENING
If the light is in the oven panel some models are part of the display, and the whole display would have to be replaced. If however the light is separate this can be replaced on its own, some models have a sealed LED, others have a small builb, on the hob the lights are usually sealed two wires are soldered to them, removal requires total dismantal of the rear of the hob and then a replacement soldered back in be careful of the polarity as incorrectly connected it will not light up. You can get parts from a local elecrical appliance store.
Or whitegoods.co.uk the model and serial numbers will be required.
Hope this is helpful
John
May 17, 2011 | Ovens
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 | Ovens
Kenmore oven doesn't light, replaced igniter and may have created a 2nd problem
If you follow the igniter wire harness, you will see a little relay in there that will probably need to be replaced.
May 30, 2009 | Kenmore Ovens
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Replacing interior oven light
Here is the manual for your unit:
Bosch HBN3550/01
The instructions are on page 31.
Hope this helps and please remember to rate this!
Dec 06, 2008 | Bosch HBN 3550 Electric Single Oven
Oven lights
i don't know your brand but ive read service bulletins on bad light sockets in ranges id try another bulb first then replace the socket
Feb 13, 2008 | KitchenAid KEBC107 Electric Single Oven
Stoves 720EF Electric Double Oven Logo
97 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
