Subwoofer installation is it possible to hook up a powered subwoofer to receiver with no subwoofer jack?
    Novelist:
  • 169 Answers
No jack =no sub audio signal so you would have to get some kind of summing filter. this would sum (mix) the two signals together and extract the sub audio from both channels in order to drive the powered sub woofer you have. could be expensive dont know.
Posted on Apr 25, 2008
How to wire sw8mk2
Does the receiver, Have a (RCA) Jack on the back of the unit ,Where it is written sub out,If it does, You need what is called a sub conecter patch cord to hook up the sub.If it is a powered sub, If the receiver does not have a sub jack you can not hook up a sub to it.
Oct 11, 2012 | Denon AVR-1612 5.1 Channels Receiver
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
May 16, 2010 | Wharfedale Topaz SW-10 Subwoofer
Need to hook up to keenwood powered subwolfer 1050sw and im a girl and dont know how
The receiver has a subwoofer out jack on the back. The powered sub has a LF input jack on the back. Connect the two with an audio cable that has 'RCA' plugs on both ends.
Mar 19, 2010 | Pioneer VSX-D409
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
    a single male rca spliting into 2 male rca's ....a signal splitter
    Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
    Pioneer VSX-505S Subwoofer Installation
    That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
    Feb 10, 2008 | Pioneer VSX-505S Receiver
    Subwoofer instalation
    Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
    Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
    309 people viewed this question
     Grubhead
    Grubhead
