Question about Bernina Sewing Machines
I need a bobbin case for a bernina bernette 90e and i cannot locate replacement parts anywhere dose anyone know where to go to find parts?
SOURCE: bernette 90E
have a Bernette 90e and it is driving me mad! I could be sewing for weeks and then for no apparent reason, while sewing, the bobbin housing pulls right out of position and jams. I have, by luck only I must add, been able to put it back into the right position but it takes me days!. I do not no what to do and am about to chuck the whole machine. please help me!!
Posted on Jan 03, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
RickE1
  • 202 Answers
SOURCE: Machine not working after bobbin installation
Hi, it may be possible that you put the bobbin in the case upside down and its turning the wrong way. Flip it over and try it. When looking at the bobbin in the case from the back and you pull the thread, it should turn clockwise.
Hope this helped as anything else may take a tech to diagnose.
Rick
Posted on Mar 25, 2009
SOURCE: 334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Posted on Jun 15, 2009
Does the bobbin case of a singer fit in the bernette 65?
No. You need to purchase a Bernette bobbin case for your machine. Check with your Bernina dealer.
Jul 18, 2017 | Singer Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Why is the bobbin casing moving? The needles keep breaking, casing not staying in place
since the bobbin case is moving, the machine needs to be checked again, and this time the hook and hook race needs to be looked at, could also have a timing problem with the needles breaking.
May 17, 2015 | Sewing Machines
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernina Bernette 65 manual does not show how to oil it- do I need to?
If there is no oiling mentioned in the maintenance part of your manual then your machine probably has nylon gears and maybe an oiling wick - many of the new machines are built this way to reduce maintenance issues.
However, if you purchased it from a Bernina dealership, I would ask them that question. Your manual probably recommends you take it to an authorised dealer periodically for a service when they would lube the parts that need it.
My Janome local dealer told me to put a drop oil under the bobbin case in my 6500P every couple of months onto the wick or if it sounds a little noisy.
Apr 15, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Im trying to put back my bobbin in a bernette 60 for bernina
The bobbin you just thread in the bobbin case and pop it back in with the tail pointing up. Now if you are talking about the hook and race cover I'll go over that aswell. The hook is the 1/2moon shaped part, put that in first, it goes opposite of the other 1/2 moon part already in there. Next put the round part over it(race cover). It goes on with the to demples to the inside and the flat part up. Then flit the tabs on the left and right over the race cover. Hope this helps
Mar 24, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Bernette 90E
Our Bernette E90 timing was off due to a jam (design flaw I think)...Instructions on how we fixed it.
1. To correct timing, tip over machine and unscrew inspection plate.
2. Find the gear and unscrew the 2 grub screws so the gear is free from the shaft
3. Turn the main sewing machine handle to manually get the hook (pointed piece) of the housing (see arrow) to be directly behind the needle
4. Hold it the tightly, and turn the handle again, the needle should be able to go up and down while holding the hook in position.
5. When the needle is at it lowest and starting to move back up and the hook is directly behind tip the machine over and tighten the 2 grub screws on the gear underneath.
6. Replace inspection cover and you’re done
Dec 26, 2007 | Bernina Bernette 75
Sewing Machines Logo
172 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
