Question about Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo
My jandy pda assistant does respond and sometimes I have to hold a button down forever. I have tried to go close to the satelitte but it still won't work and I have to usually manually put my pool in time out to make changes. Also, my spa light is on non stop at night and I don't have it programmed to do that. Help please
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Try changing the channel to one or two numbers higher they come from the factory on number 5 hold the up and down arrows for 10 seconds it will show channel up or down change channel then go to the antenna take off the front cover and move the little button to learn when it promps you to turn back then it should connect
Posted on Nov 12, 2014
5 Suggested Answers
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
thepool
  • 78 Answers
SOURCE: Describe your Jandy Laars Lite2 Pool
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Posted on Apr 22, 2010
adamh294
  • 310 Answers
SOURCE: dont know how to start
If you let me know what heater it is I can help. Not enough info here.
adamh@newconceptchem.com
Posted on Oct 27, 2010
adamh294
  • 310 Answers
SOURCE: Have a 3.5 year old Jandy Aqualink RS 4 --- the
It is most likely not a bad reading on the on the display.
One culprit of a false temp reading could be:
If the temperature sensor is installed after the heater and the circulation pump is clogged or failing, this would allow super heated water to reach the temperature sensor and give you that reading. However, most pool/spa heaters have a high limit switch that would shut down the heater @ 150 degrees F. So this is also unlikely.
The most reasonable answer is to replace the temperature sensor.
If you refer to page 22 in this manual http://www.jandy-downloads.com/pdfs/Allbutton_manual.pdf
you will see that the temperature sensor is installed on terminals 5 and 6.
Trace these wires. They will goto a thermowell (which holds the temperature sensor) either in the pool plumbing, or to a temperature sensor in the heater itself. Temperature sensors when in the heater are located typically above the inlet/outlet header. There will be some disassembling required to access it in this case.
If it is in the heater and you need more help, e-mail me @ adamh@newconceptchem.com
Please take the time to give me a positive rating on this post if I have helped.
Thanks
adam
Posted on Nov 02, 2010
Testimonial: "Thanks for the prompt response. I'm at work now but I will follow your instructions when I get home. I had a feeling that it is a 'bad' sensor. "
Jandy Aqualink RS-8156 stopped connecting. will not work
check to see if red 4 pin connector is connected from antenna to the PCB board if so then check to see if battieries are low if not change channel while on hold up and down buttons at same time for about five seconds then arrow up defalt setting is 5 change up a few numbers then go to the antenna take off the cover set the button to learn PDA will connect and tell you to put button back
Sep 06, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
The system keeps showing "no flow" and the hand held asks to check aquapure.
inside aqua pure there is a card hooked to the salt sensor cable there is a button to hold down until a green light shows then see if you get flow if not need new sensor
Jun 20, 2013 | Jandy AQUALINK RS TELELINK KIT
Jandy pda time keeps resetting back to default and the spa blower will turn on and off by itself
go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
Jun 09, 2013 | Jandy Aqualink Pda Ps8 Wireless Handheld...
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
Button on jandy pda 8265 broken
See this thread:
http://www.troublefreepool.com/how-to-fix-your-jandy-pda-for-15-t52166.html
May 13, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Need to change channels on jandy rs dpa
turn on PDA hold down up and down buttons at same time it will say change channel go up a couple 5 is default then it will tell you to program antenna open front cover you should see a little reset button push it to program then push the reset button it will blink then tell you to turn the switch back then it will connect make sure the 4 pin connectors are plugged in and the wire isn't cut
Mar 24, 2012 | Jandy AQUALINK RS TELELINK KIT
Need manual for pda pool digital assistant
go to jandy website they have them on there website
Nov 24, 2010 | Jandy Aqualink Pda Ps4 Wireless Handheld...
My Jandy PDA has stopped working. It started to
need new PDA hand held make sure to replace with same model old ones 800 MHz new ones 900 MHz means change antenna also
Apr 05, 2010 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Logo
268 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
