Question about Pioneer SD-P50A5-K 50" Rear Projection Television
TV will not power up, power light turn on momentarily then turn off
  • Pioneer Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Pioneer, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand,
http://www.freelists.org/post/techassist/FIXED-Pioneer-SDP50A5Kneed-to-access-service-menu,1
Posted on Jul 31, 2010
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
My HDTV has gone out.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 14, 2015 | RCA Televison & Video
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
Power button flashes red. TV comes on momentarily
this is a inverter board defective. please change-it
Oct 31, 2009 | Panasonic TH37PX60 37 in. Plasma...
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Tv won't turn on, power led just flashes
I have the same problem. After about 2 seconds the system status light blinks red and the system needs to be reset. The only way to turn the system on is to unplug from power for 5 minutes and then plug back in, wait for light to stop blinking and then turn on. I have cleaned the filter on the left side. The model is Mitsubishi WD-62725. any ideas?
Nov 26, 2007 | Televison & Video
Toshiba 50A60
take your tv to a tech it needs repair.if you are not a tech you wont be able to do it your self.the tv is having problem in the power supply and other related circuit.good luck.
Apr 03, 2007 | Toshiba 50A60 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
75 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
