Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Replaced the belt and roller. but it keeps chewing
Have a Eureka 4870 smartvac. Have replaced the roller brush and belt, but it keeps chewing up the side of the belt. Seems to wear up at the top where the blt goes over a shaft - from the motor?
3 Suggested Answers
galati2k
  • 281 Answers
SOURCE: new brushroll for eureka smartvac 4870; bristles too long to turn
make sure you have the brush roller in correctly and in all the way.the ends fit in the slots in a certain position
Posted on Apr 05, 2009
Vac Belts
  • 701 Answers
SOURCE: My Eureka The boss Smartvac Model #4870 roller
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Posted on Dec 11, 2009
I was replacing the belt on my Eureka Smartvac 4870 and one of the felt gaskets (or part of it) popped out. I thought I put it in correctly, but the first I used it after replacing the belt, the gasket got...
I'm no expert but if you mean the felt on the roller, you have to replace the roller (expensive,esp. for such a minor part). So. I found some felt with adhesive in the craft section at Wal-Mart, trimmed it to fit and done deal. Felt reduces friction.
Dec 08, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Belts on my vacuum last only a short time, the keep getting chewed up. Seems that the belt does not align properly between the brush bar and the motor shaft.
The belt is either contacting the
1. Check to see that the roller is installed properly (make sure it is not reversed and that it is all the way in).
2. Check to see if there is any play in the motor shaft and that the motor has not come loose.
3. Check for wear on the roller where the belt contacts the roller. If this is worn you may need a new roller.
4. If the belt is still contacting anything besides the motor pulley and the roller at this point, you still have a problem.
Hopefully this will help. Let us know how you make out and good luck!
Mar 11, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Bissell 4870 Belts
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roller spins until it touches the carpet, then stops.
That means that the belt is stretched or worn. Here is a link to the replacement belts you need and a manual which has instructions:
Eureka Smartvac 4870 Belts
Dec 06, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Belt on motor roller
no only take the bottom off ,there will be three screws,take the belt put in over the shaft of the motor , loop it ,run it over the silver spindle to the brush assembly ,replace the brush in the slot that it came from,the belt now is over the motor shaft running over the spindle ,and over the brush assembly,replace the three screws and you should be good to go.
Jan 31, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
51 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
