Question about Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Pakel washer GWL11 and it has developed a small leak under the washer. The cycle stops at rense and just quits. Any suggestions on what needs replacing?
  • 70 Answers
Sounds like it could be overfilling Just a little and while it is agitating it will be splashing over, To fix this you will need to replace the MCU,
Posted on Jul 31, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Wont wash just flashes the wash light
most likely the controll board at the bottom has gotten wet due to accidentally overloading the washer.Remove the droor and dry out the board with a hair dryer.That is the most common cause of problems with the fisher pakel dish washers
Apr 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
4 year old Fisher Pakel washing machine
Hi and welcome to FixYa!
Some things to check- Start with the water pump underneath the machine in the right-front of the unit. Look for signs of rust or leakage, that would be the most likely cause. Also check the operation of the diverter valve, inspect it to make sure there is not something like a lint ball or small object caught in the flapper; this can allow water to seep out of the diverter when it is supposed to be sealed in the spin or drain cycles and this seepage will get on the tub's rim as it spins and cause a leak on the floor. This kind of leak will cause water to appear as if it is leaking between the top and the cabinet.
Word of caution- the water pump is electric, and if you allow this leaking to continue, it can actually short out boh the water pump as well as the machine control.
If afer you solve the issue, if you find that I have accurately described the problem, a FIXYA rating is greatly appreciated. Thanks!
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Pakel 4 years old Water leak
possible its form the pmp assy underneath, youll need to tip unit back( the bottoms open, look for leaks, should be quite noticable
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Fisher n pakel won't drain
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
Feb 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
127 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
